Old 10-07-2011, 07:24 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Default Can it be timed?
Question on the timing 1997 360 V-8.
I am new to the electronic ignition/fuel injected motors ( I am a seasoned Carburated Chevy 350 guy )
Can I set the timing by turning the distributor ( old school style ) to get more power, better gas mileage...ect....
My old Chevy I would set the timing @ ? degrees BTDC and it would get better gas mileage, more power, sound better ( nice lope ) but that also included adjusting the carbs where I dont think I can adjust the fuel supply unless the computer will do that automatically??
Any input on this would be great as I am getting really crappy gas mileage ( oil changed, New cap/rotor/plugs/wires, cleaned throttle body and air filter )
Thanks
Mike
Old 10-09-2011, 01:48 AM
Ram BeaSST Ram BeaSST is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: SS/T
Color: White with Blue Stripe
Ram BeaSST is on a distinguished road
you might want to read the second post in this thread:
http://ramforumz.com/showthread.php?t=93185
it looks to be what you want to accomplish. hope it helps.
CAI, blue 8mm spark plug wire set, platinum spark plugs, 180* t-stat
Old 10-09-2011, 01:58 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
No, the distributor twist trick ended when the Magnum began, 1992 on the 5.2 and 1993 on the 5.9. You'll have to resort to an electronic tuner.
Old 10-09-2011, 02:50 AM
sonocativo's Avatar
Rep:210
something like the flashpak?
Mike
Old 10-13-2011, 12:39 AM
Rep:85
I haven't really done anything with tuners. As linked, you can get 3-4 degrees initial advance with the crank sensor mod. Beyond that you'd need a tuner. Sorry I just haven't used them.
