Old 10-10-2011, 07:50 AM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
Originally Posted by garner View Post
Don't forget the transmission getting destroyed. And I don't think he can do that much boost cause the 4th gens have a 10.5:1 compression ratio
The VVT 5.7 can handle up to 9psi, I am running 7.5 - 8 to play it safe.
Old 03-10-2012, 11:14 PM
smokin20s smokin20s is offline
Rep:16
smokin20s is on a distinguished road
I'm doing a remote mount on my '03. How does the STS kit ket the oil back the motor? I know it has an electric pump.I've got that, but where does it pump to? Drill and tap block? Oil pan? I'd rather not do either of those. Maybe a custom oil fil cap with a hose fitting?
Old 03-10-2012, 11:30 PM
I push the skinny pedal
Rep:3308
If I remember correctly, it acts like a remote oil filter, so it taps off of the oil filter and returns to the same place.
Kurtis
Old 03-11-2012, 05:53 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
^^ What he said.
There are oil filter "sandwhich" adapter that you can get that provide you in "in" and an "out" port. Moroso makes one I believe. A lot of racers get them and use them for oil coolers
2011 Big Horn 4x4 -SnowWhite-
Old 03-11-2012, 08:34 AM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:23
FrostKing is on a distinguished road
The oil supply is from a 1/8" tee installed before the stock oil pressure sending unit on the block, next to the oil filter. Also, the return line has to be at zero pressure and STS provides a new oil fill cap drilled and tapped with a pneumatic quick-connector. While being convenient it has the problem of this oil getting aerated and sent through the breather line in large volumes. Dumping the oil into the oil pan above the oil level is the best choice.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 03-12-2012, 03:34 AM
Rep:16
I've use sandwich plates before, i don't remember there being an in port, only outs. I damn sure don't want foamy oil going through the motor. i don't mind drilling the pan, if I can yank it off in the truck. Anyone know? Can i pull the oil pan off, with the motor still in the truck?
Old 03-12-2012, 03:40 AM
Rep:16
I just checked, Moroso does have a plate with an in and out. Sweet!
Old 03-12-2012, 01:58 PM
RamTex's Avatar
RamTex RamTex is online now
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
well what you could do is get a telesopic magnet and stick it in the drain hole next to the area you will be drilling and it will catch any metal shavings that are produced while drilling... or just get that plate... dont think you want to pull the oil pan with the motor in the truck you might have to unbolt the motor mounts and jack the engine up a bit to get it out... just a guess.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-13-2012, 12:08 AM
FrostKing's Avatar
Color: Graphite
Rep:23
2WD yes, without lifting the engine. 4WD I don't know.
Sold: 2003 RCSB 2WD
Custom Holset Turbo on 5.7 HEMI weuvej Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 19 12-16-2013 09:07 PM
Turbo fail? RPM drop when I rev the engine to fast KThiara Cummins Diesel Specific Topics 2 07-26-2011 04:28 AM
Rear-ish mounted turbo bigtallcampbell Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 27 03-12-2011 04:50 PM
Hey guys new n looking for advice on turbo chaging jdmer2 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 5 03-24-2010 02:58 AM
Turbo kit? gtfloyd Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 02-08-2010 08:05 PM
