Old 10-08-2011, 02:04 PM
ArkRAM11's Avatar
ArkRAM11 ArkRAM11 is offline
Vehicle: 2011 Ram 1500 Laramie
ArkRAM11 is on a distinguished road
Default Bilstein 5100's and 35"s
I have looked all over for a straight answer to this and cannot find it. I have a 2011 Ram 1500 cc with Bilstein 5100's set on the highest setting. Im looking at adding new wheels and hopefully 35" tires. The wheels I'm looking at buying are RBP 93R in 20's. The come in 4 different offsets being +10, 0, -12, and -25. I'm also looking at Nitto Trail Grapplers in either a 295/60 R20 which is 34.45 in. tall by 12.13 inches wide, a 295/65 R20 which is 35.47 in. tall by 12.13 inches wide, or a 35X12.50 R20 which is actually a 35.04 in. tall by 13.39 inches wide. What I'm trying to find out is simply will they fit without rubbing? if so what would be the best choice and combo of the offset on the wheels and the dimensions of the tires. Any and all help is greatly appreciated.
Old 10-08-2011, 08:20 PM
WyGuy's Avatar
WyGuy WyGuy is offline
Vehicle: 2012 Dodge Ram
Trim Level: Outdoorsman
WyGuy is on a distinguished road
Would love to know too!
Old 10-08-2011, 08:42 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
The 295/65 R20s with a -25mm offset should work perfectly.
Dillon-aka, The Little Kid
Old 10-08-2011, 11:05 PM
ArkRAM11's Avatar
Thank you. I'm kind of hoping to go with the -12 offset. Do you think the width will be the bigger problem than the height? Currently with the leveling kit and stock tires my truck sits just shy of 39 inches from ground to the fender well. Is anyone running 35"s with just a leveling kit on a 4th gen?
Old 10-09-2011, 12:53 AM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I think the 0 and -12 will work too.
Old 10-09-2011, 01:06 AM
I'm running a 285/75X18 (34.7") tire on a +18mm offset wheel with no problems. Of course, I have a 4" lift.
Really, I'm thinking the +10 or 0mm offset wheel will work with a 295.
The only things I am not sure of is the dimensional differences in the 4th gen wheelwells vs. the 3rd gen trucks and just how far up you have to go to clear a 35" on a 4th gen truck.
Good luck. I'd suggest you go see a tire and wheel dealer in your area. Most will either measure and tell you exactly what will fit and some will even mount up tires and wheels for a fitment test.
Old 10-09-2011, 05:44 AM
RPD RPD is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crewcab 4x4
RPD is on a distinguished road
I am going to be watching this thread closely as I am looking for the same info! Bump it up
Old 10-09-2011, 11:40 AM
ArkRAM11's Avatar
Anyone with pics that can verify?
Old 10-09-2011, 11:42 AM
2011SThemi 2011SThemi is offline
Vehicle: 2011 Dodge Ram 1500
2011SThemi is on a distinguished road
i'm running trail grapplers in a 295/70/18 with bilsteins at the highest setting and the rims are 4.5backspacing 0 offset
Old 10-09-2011, 12:00 PM
ArkRAM11's Avatar
Thank you 2011SThemi, according to nittos website thats a 34.57 which is pretty much the same as the 295/60 R20 im looking at but the R18's are about a half-inch narrower. Do u have any issues with rubbing at all? Any pics?
