Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 10-08-2011, 07:28 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Default DIY An easy way to add Homelink
I've missed not having the Homelink option in my 2010 Ram 1500 SLT crew cab. Our Hyundai Sonata has Homelink and compass incorporated into the main rear view mirror, so I investigated the availability of aftermarket mirrors I could install in the Dodge. Turns out the same company (Mito Corp, http://www.mitocorp.com/) that supplies these mirrors to OEM manufacturers also makes them available for the aftermarket.
The Gentex line of auto-dimming mirrors come with various options such as compass, map lights, outside temp, backup displays and Homelink. The kit I ordered is the Gentex 41A (part #50-GENK41A), which only has the Homelink option. The kit provides the mirror with mount, detailed instructions, wiring pigtail, a telescoping wire cover, several T-Taps and plastic zip-ties. Cost was $169 ordered from Amazon with free shipping.
Mounting the mirror
The mount on the Gentex mirror is exactly the same as the OEM mirror, held in place with a torx set screw. Simply use a T20 bit or driver to loosen the screw, slip the old mirror off the windshield lug, slip the new mirror on and tighten the screw just snug. Takes less than a minute to perform this task.
Wiring the mirror
The mirror requires three connections, switched 12 VDC (ignition switch on), unswitched 12 VDC (constant) and ground. The pigtail comes with a plugin connector for the mirror and is 6-7 feet long. Why so long? The instructions suggest running the pigtail from the mirror to the headliner, across and down the A pillar and then tap into the harness near the main junction box under the dash. I decided this was over kill for a 4th generation Ram. Inspired by Bock's post describing the rewiring of a LiveLink module (http://www.ramforumz.com/showpost.ph...53&postcount=1), I assumed all the connections the mirror needed could be found in the overhead console. Bock describes removal of the console face from the ceiling. RamTech provides detailed instructions for removing the console face and description of the connectors found inside (http://www.ramforumz.com/showpost.ph...99&postcount=4).
Grab the console face by the edges on both sides about even with the rear window slider switch and pull straight down. You will swear you are about to break something when the brass clips pop loose. Slide the console back about an inch or two to clear the front hangers. Disconnect all the connectors and set the console face aside. I found it easier to first unplug the rear window switch from the console face and then disconnect the switch from the harness. With a multimeter, I checked and confirmed that the solid red wire on the flat black connector to the compass is unswitched 12 VDC and the pink w/ yellow stripe wire on the square orange connecter to the slider switch is switched 12 VDC. I found the solid black wire on the compass connector went to ground.
I shortened the mirror pigtail to ~18" in length and re-crimped shielded spad connectors. The front edge of the headliner is not sealed. Plug the pigtail connector into the mirror and feed the the other end over the headliner and into the the console mount. Connect the mirror pigtail with the T-Taps as shown.
Snapping the telescoping wire cover in place to cover the exposed portion of the pigtail and reinstalling the console face finishes the job.
Instructions also are provided for programing to both conventional and rolling code devices. The auto-dimming feature is a nice addition as well.
Old 10-08-2011, 07:30 PM
MADDOG MADDOG is offline
Rep:22
Very nice writeup!!!
Old 10-08-2011, 07:35 PM
BWG56's Avatar
BWG56 BWG56 is offline
Color: Mango Tango
Rep:19
BWG56 is on a distinguished road
nice job
Old 10-08-2011, 07:42 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Excellent idea and writeup, reps to ya.
Old 10-08-2011, 11:06 PM
Rep:26
Originally Posted by BWG56 View Post
nice job
Thanks guys. I appreciate the kind words.
Two items I forgot to mention in the original post;
1) The Gentex mirror can be programed to control three remote devices.
2) Disconnecting the compass module confuses it, requiring calibration. Instructions for calibrating the compass are in the owners manual.
gentex homelink mirror
Homelink programming problem solved! jlcosby 2011 Dodge Ram Forum 20 04-30-2015 11:08 AM
Swapped RES for RBZ... EASY EASY heavyzee 2010 Dodge Ram Forum 35 12-12-2012 09:19 AM
Homelink hates my garage door opener! Stump3r 2011 Dodge Ram Forum 22 10-16-2012 10:35 AM
I'm new rodgtwo Newbie Checkin! 12 06-08-2011 10:01 PM
Adding Homelink davidhibler 2010 Dodge Ram Forum 1 01-05-2011 07:37 PM
