Old 10-08-2011, 08:31 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default Alpine to JL Audio- Subwoofer
This is the second stage in the conversion of the stock Alpine speakers in my 2011 Ram CC Sport to JL Audio.
The subwoofer used to replace the stock Alpine 8" subwoofer is the JL Audio SB-D-QDRAM/10w3v3. For more details, go here:
http://mobile.jlaudio.com/products_s...hp?fit_id=1440
The amplifier used is the JL Audio XD 600/1. For more details, go here:
http://mobile.jlaudio.com/products_a...hp?page_id=301
Also, the JL Audio harness XD-CLRAIC2-SW was used to connect to the stock sub harness providing an RCA signal to the amplifier. This harness is detailed here:
http://mobile.jlaudio.com/products_c...l.php?cat_id=5
As for amplifier wiring, the JL Audio XD-PCS4-1B was utilized. It can be researched here:
http://mobile.jlaudio.com/products_c...l.php?cat_id=9
Last but not least, a level controller, JL Audio HD-RLC was utilized. It can be found here:
http://mobile.jlaudio.com/products_a...hp?page_id=308
Now that all of that is out of the way, let's get to the good stuff!
I did not follow the JL Audio instructions which asks you to drill through the floor and bolt the sub box down. Instead, I fashioned a black bracket similar to the stock sub enclosure and bolted the JL box down in the exact same location.
The wiring was uneventful as the plastic block off plate beside the brake master cylinder made for an extremely easy location to run the line. I hate to see audio wiring in the engine bay, or anywhere for that matter, so everything was loomed identical to stock and hidden.
The amplifier was mounted on the non-sub side of the cargo area. All wiring was run under the carpet and amp and then connected. The HD-RLC was mounted under the steering wheel and to the left. Easy to get to and adjust and not highly visible.
Amplifier Settings: 24db Crossover/50hz/No input sensitivity adjustment.
Results: Wow! Absolutely breathtaking bass response and finally, the entire system rocks! This sub setup can play everything from Rap to Orchestra and sound like it's perfectly suited to all formats. I couldn't be happier!
2012 R/T 392
Old 10-08-2011, 08:32 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
More pics.............
2012 R/T 392
Old 10-08-2011, 08:35 PM
Nice work! I've stickied this one too.
Old 12-01-2011, 03:56 AM
jamesyl jamesyl is offline
Vehicle: none
jamesyl is on a distinguished road
great post i hope to have one soon this year ends!!!
[url=http://www.orientalrugcareny.com/New-York/Brooklyn/park-slope-carpet-cleaning.html]Alpine Carpet Cleaning[/url]
Old 12-05-2011, 02:01 AM
hemirae hemirae is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie CC
Color: Black Crystal Pearl
hemirae is on a distinguished road
How did you connect this to the stock sub harness? Did you use a 4-way harness/connector? If so, where did you buy it from?
I would like to copy your sub-replacement setup and like you I do not like cutting the stock connectors/harness.
Thanks in advance.
Old 12-30-2011, 08:26 AM
davesu davesu is offline
Vehicle: none
davesu is on a distinguished road
thanks for posting!keep it up!
Old 01-10-2012, 05:57 PM
ram7833's Avatar
ram7833 ram7833 is offline
Vehicle: 2011 Ram outdoorsman
Trim Level: Quad Cab
ram7833 is on a distinguished road
what kinda sub box did you use ? is it homemade or did you buy it ?
Old 01-28-2012, 10:01 AM
Cowboy Cowboy is offline
Vehicle: 2009 Ram 1500
Trim Level: SLT Quad 4.7
Rep:14
Cowboy is on a distinguished road
ironchef...the install looks great! definitely think of going in the same direction.
ram, this is the sub used (noted at the beginning of his post: The subwoofer used to replace the stock Alpine 8" subwoofer is the JL Audio SB-D-QDRAM/10w3v3. For more details, go here:
2009 Dodge Ram 1500 SLT, 4.7, Brilliant Black, Quad Cab, de-badged
Old 04-03-2012, 01:03 AM
Bg Rd Ram's Avatar
Bg Rd Ram Bg Rd Ram is offline
Vehicle: 2012 Ram
Rep:19
Bg Rd Ram is on a distinguished road
I recently put a set of subs beneath my seat also, but when people sit in the back they can feel the grills under them. Are you running into the same problem? If so, do you know how to fix it.
Old 04-03-2012, 01:07 AM
wmckee wmckee is offline
Vehicle: 2012 Dodge Ram
Trim Level: big horn
wmckee is on a distinguished road
Getting the pricing done for this now, I am more than likely going to replace the 4 6x9's as well.
4TH Gen: Stock Alpine Subwoofer Specs ironchef2011 Custom Dodge Ram Interior Modifications - Custom Audio / Video 16 02-19-2015 07:57 AM
FS: Fourth Generation Alpine Subwoofer! ironchef2011 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 7 09-24-2011 11:57 PM
Audio Enhancers 10" sealed sub enclosure (with Alpine components) for CC skruface Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 07-17-2011 09:55 AM
alpine subwoofer onewheelregulator Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 8 03-25-2011 03:04 PM
FS: Massive Audio CK6, Nano N3, and QC15 subwoofer chithead Miscellaneous For Sale 3 03-19-2011 04:45 PM
