Old 04-12-2013, 10:11 PM
jeepguy's Avatar
jeepguy jeepguy is offline
Vehicle: 2013 Ram Sport
Color: Deep Cherry Red
Rep:29
jeepguy is on a distinguished road
The Alpine sub is a dual voice coil sub and the factory harness has 4 wires going into it. Is that one pair of wires for each voice coil?
If so, how did you feed the signal to your aftermarket amp? Did you just use the signal from one set of voice coils?
Old 04-12-2013, 10:16 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
I added a bare wire/RCA harness. There are four wires going to the stock sub, a left and a right feed. So one pair translates to one single RCA. Both pairs equates to two RCA's. then I just plugged these RCA's into my amplifier that was designed for this application.
2012 R/T 392
Old 04-12-2013, 10:24 PM
jeepguy's Avatar
Rep:29
Why would there be a left and right feed going to the sub? The amp is not in the sub. The OEM Alpine amp should be mixing the left and right feed and sending one signal to the sub.
It makes sense that you could trick your aftermarket amp by feeding it one pair as a left feed and the other as a right feed.
As for the harness, I bought the same connector the factory uses and I'm going to make a harness that plugs into the truck and has RCA connectors on the other end.
Old 04-12-2013, 10:37 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Sorry for the confusion. What I meant by right and left feed was for the RCA, not the sub. The factory amp, not located in the sub, send two pairs of outputs to the single, dual voice coil sub.
Like you, I also sourced a stock harness connector and then wired it into a pair of RCA's.
2012 R/T 392
Old 04-12-2013, 10:59 PM
jeepguy's Avatar
Rep:29
This is the OEM wiring diagram. Is this what you did?
Old 04-12-2013, 11:18 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Exactly. I disconnected the entire factory sub enclosure and unhooked the wire harness which is under the enclosure. I then connected my new harness and solder/heatshrunk the new RCA ends.
2012 R/T 392
Old 04-30-2013, 07:04 PM
jeepguy's Avatar
Rep:29
I just made the harness: http://www.ramforumz.com/showpost.ph...68&postcount=6
Old 05-01-2013, 11:45 PM
hemirae hemirae is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie CC
Color: Black Crystal Pearl
hemirae is on a distinguished road
[QUOTE=jeepguy;1068196
As for the harness, I bought the same connector the factory uses and I'm going to make a harness that plugs into the truck and has RCA connectors on the other end.[/QUOTE]
Where did you buy the harness for the sub? Any part #?
Old 05-15-2013, 10:10 AM
velocityss1985 velocityss1985 is offline
velocityss1985 is on a distinguished road
What turns the amp on and off? Remote wire? Or does this amp turn on and off through the RCA's? Another question is there is no line level converter. Isnt the feed coming from your connector you made an amplified signal?
Jeff
Old 05-16-2013, 09:32 AM
jeepguy's Avatar
Rep:29
I still need to get a signal from the CANbus to control the amp. Various companies make such adapters.
JL amps allow for speaker level inputs, so this should be OK. I could get a line level input from the back of the OEM amp, but that would be more work.
4TH Gen: Stock Alpine Subwoofer Specs ironchef2011 Custom Dodge Ram Interior Modifications - Custom Audio / Video 19 04-08-2015 04:17 PM
FS: Fourth Generation Alpine Subwoofer! ironchef2011 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 7 09-24-2011 10:57 PM
Audio Enhancers 10" sealed sub enclosure (with Alpine components) for CC skruface Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 07-17-2011 08:55 AM
alpine subwoofer onewheelregulator Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 8 03-25-2011 02:04 PM
FS: Massive Audio CK6, Nano N3, and QC15 subwoofer chithead Miscellaneous For Sale 3 03-19-2011 03:45 PM
