Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-08-2011, 09:48 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
Default 2011 rear sway bar torque specs
anybody got 'em? finally got all the pieces for the factory set-up. many thanks.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 10-15-2011, 12:52 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, don't have an answer, but I can offer to this back to the top!
Old 10-15-2011, 09:14 AM
Rep:19
thanks, i'm gonna head to pep boys and see if there's a haynes manual available. pics later.
Old 11-03-2011, 12:36 AM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
Fullmonte60,
I bought a 2012 Express and it didn't have a rear sway bar either. What size bar did you go with 16MM, 18MM or 20MM and do you have the part number for the bar and bushings?
Thanks in advance.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 11-07-2011, 11:05 PM
Rep:19
hey- sorry for the delay. the bar was 68061786-AA and the bushings were 68048854-AA. not sure of the mm size. looks pretty thin but it helped quite a bit...lol. good luck with yours.
Old 11-08-2011, 12:48 AM
jmr's Avatar
jmr jmr is offline
Rep:74
Thanks for the reply it's probably the 16MM diameter bar which is what the factory puts on the 2WD Reg Cabs....when they do install them.
Old 11-10-2011, 04:08 AM
Jorde's Avatar
Jorde Jorde is offline
Trim Level: sport
Color: silver
Jorde is on a distinguished road
Tighten the stabilizer bar retainer bolts (3) to 50 N·m (37 ft. lbs.).Tighten stabilizer link lower nuts (2) to 107 N·m (79 ft. lbs.).
Old 11-10-2011, 09:19 AM
Rep:19
i need to upload a pic.
Old 11-10-2011, 09:26 AM
jmr's Avatar
jmr jmr is offline
Rep:74
Jorde, Thanks for the torque specs.
I'll be installing the rear bar soon since it got shipped yesterday from mopar-wholesale.com. I can't figure why Dodge didn't install it on the Express when they had it on the 2012 Reg Cab ST short bed models 4x2 w/ V6's that were on the dealers lot.
Old 11-14-2011, 10:50 PM
jmr's Avatar
jmr jmr is offline
Rep:74
I installed the 16MM rear swaybar tonight, it's the same part number as yours and is what comes on a
4x2 Reg Cab Short Bed provided the factory actually installs one. Also I replaced the front upper swaybar
link rubber bushings with Red urethane bushings from Autozone. It helps the front bar react better and
is a cheap $12.99 mod. I must say that the trucks handling has realy improved now.
I need torque specs! or: Haynes Manual Sucks Rusty Nib 5.7L V8 Specific Topics 7 11-10-2011 04:28 AM
torque specs arnsr 5.7L V8 Specific Topics 2 10-15-2010 03:46 PM
Rear Sway Bars ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-16-2010 10:37 PM
Rear Sway Bar 1500 Plainbroke Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 09-28-2009 12:48 AM
Pinion nut size on rear diff and torque by hand? skirush Suspension 0 07-23-2009 08:30 PM
