Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-14-2011, 10:59 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
do you have a part # for the front bushings? good idea. thanks.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 11-15-2011, 01:14 AM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:74
jmr will become famous soon enough
They are Energy Suspension end link bushings part # 9.8105R that are sold for $12.99 at AutoZone in a
Yellow blisterpack that contain 8 Red bushings and 8 washers. The hole in the middle of the new bushing
is 3/8" which is too small for the RAM and needs to be open up to a little
over 7/16", I used my drill press for that task.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 11-16-2011, 08:43 AM
Rep:19
great info - thanks again.
Old 05-06-2012, 01:14 AM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Originally Posted by jmr View Post
I installed the 16MM rear swaybar tonight, it's the same part number as yours and is what comes on a
4x2 Reg Cab Short Bed provided the factory actually installs one. Also I replaced the front upper swaybar
link rubber bushings with Red urethane bushings from Autozone. It helps the front bar react better and
is a cheap $12.99 mod. I must say that the trucks handling has realy improved now.
Is this what you guys ordered? I don't see an option for that 16MM specification:
Part Number 68061786AA
Part Name Stabilizer bar Regular cab
Online Price $171.10
www.mopar-wholesale.com
Originally Posted by Jorde View Post
Tighten the stabilizer bar retainer bolts (3) to 50 Nm (37 ft. lbs.).Tighten stabilizer link lower nuts (2) to 107 Nm (79 ft. lbs.).
Thank-you.
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 05-06-2012, 10:12 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Just a pic to go with jorde's torque specs bud.
Old 05-06-2012, 02:31 PM
Rep:19
that's the part # !
I need torque specs! or: Haynes Manual Sucks Rusty Nib 5.7L V8 Specific Topics 7 11-10-2011 04:28 AM
torque specs arnsr 5.7L V8 Specific Topics 2 10-15-2010 02:46 PM
Rear Sway Bars ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-16-2010 09:37 PM
Rear Sway Bar 1500 Plainbroke Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 09-27-2009 11:48 PM
Pinion nut size on rear diff and torque by hand? skirush Suspension 0 07-23-2009 07:30 PM
