A/C does not blow much air - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram – 1993 & Older Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-05-2010, 01:30 AM
dcchico dcchico is offline
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
dcchico is on a distinguished road
Default A/C does not blow much air
I have a 1983 Dodge Ramcharger and my A/C does not blow much air. I have it on high and it feels like it's on low. I recharged my A/C but it still does not blow hard....or hard enough to cool down those who sit up front let alone the back seat. What do I need to do to fix or what should I do to increase the flow of air so my family and I can keep cool during the summer months here in Texas?
Old 04-05-2010, 07:48 AM
trx4's Avatar
trx4 trx4 is offline
Vehicle: 2006 Q-Cab
Trim Level: SLT TRX4
Rep:45
trx4 is on a distinguished road
Dues the air move when you change the air flow from top bottom(defrost to floor) if not it’s probably the actuator. If the air dues move thin it’s probably the fan (the motor is not working or the fan itself has come off the motor shaft)
Old 04-05-2010, 09:43 AM
Rep:1915
Are you on fresh air intake or recirc? If it does it on either setting, remove the blower motor and check for any obstructions.
Old 04-05-2010, 10:13 AM
Thank you for the info I shall look into it right away.
Old 04-05-2010, 10:23 AM
trx4's Avatar
Vehicle: 2006 Q-Cab
Rep:45
Ya even with the grill over the intake it is possible to get trash in the air ducked.
Old 05-30-2011, 06:07 PM
ZX10R Ninja ZX10R Ninja is offline
Vehicle: 2004 Dodge Ram 1500
ZX10R Ninja is on a distinguished road
I have a 2004 Ram that the air flow has diminished bigtime.
It sounds like there is some paper or something somewhere blocking the air path. I'm gonna pull my blower motor and see if there is something in it.
You know that sound that paper makes when you hold it tight in the wind?
That fluttering noise? That's what I'm hearing.
Old 05-30-2011, 08:03 PM
sonocativo's Avatar
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
Clogged cabin air filter maybe?
I Am Groot !
Old 08-14-2011, 02:39 PM
8302 8302 is offline
Vehicle: 2003 dodge Ram
Trim Level: laramie
Color: charcoal
8302 is on a distinguished road
I have a similar problem with my '03. The AC blows great for about 20 minutes and then the air flow diminishes. I increase the fan speed but the flow continues to diminish to the point that there is hardly any air flow at full fan speed. I was interested in the comment about the cab filter, perhaps mine is freezing up or something. Can somebody describe if that is possible and where the filter can be found?
Old 09-09-2011, 12:19 AM
sonocativo's Avatar
Rep:227
If you have a cabin air filter, it is located behind the glove box. There is a rectangular door that unsnaps and the filter slides out. Not all trucks/cars have them.
I Am Groot !
