tonneaucovered.com
Old 10-09-2011, 08:37 PM
cueman cueman is offline
Vehicle: 2010 Ram Laramie 4x4
cueman is on a distinguished road
Default 2010 rear seat
Is there any way to fold the rear seats DOWN on a 1500 ram Laramie?
Old 10-09-2011, 08:43 PM
Jsty093083 Jsty093083 is offline
Vehicle: 2010 Dodge Ram 1500 Big Horn
Trim Level: SLT Big Horn
Color: Blue
Rep:17
Jsty093083 is on a distinguished road
If its like my big horn and the bottom flips up, then no, from what i can read it takes removing 4 bolts to get the seat even out, if you wanted to put a cover on it.
RC leveling kit. American eagle 20x10 -21 offset wheels. EGR flat black pocket style flares. War paint hood decal. Magnaflow cat back system. AFE stage 2 intake. Diablosport trinity w/ Hemifever tune. Sony XAV-701hd w/ 10" kicker. Air lift 1000 rear leveling kit.
Old 10-09-2011, 09:20 PM
Thanks, this is my first dodge and I just thought I was stupid....
Old 10-10-2011, 12:56 PM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
I had the same problem. This is my first Ram and I was SURE I was missing something... especially while struggling to attach the upper anchor on a childs car-seat.
Ambitious, but rubbish!
Old 10-10-2011, 01:59 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
hey everyone, there is a way to do it! first off "normally" the back of the seat does not fold down. in the back there is an anchor welded to the rear of the cab, and on the seat there is a J shaped piece of steel that hooks in this anchor to hold the seat. Well if you notice, when we lift the bottom of the seat up, the back also slides up a bit, but not enough to disengage that hook on the back. Heres the fix. remove the 4 bolts that hold the seat to the floor. get some 1/2 inch spacers... what you use is your choice, washers, pipe cut off etc etc. place these spacers UNDER the seat bracket (between bracket and floor), put the bolts back in, and voila now when you lift the bottow of the seat, the back will raise far enough to clear the hook, and you can fold the back down to get at the baby seat anchors etc. when the seat is in the usable position, the lock still catches as its supposed to .... hope this helps guys!!!
P.S. may need to play with the spacer thickness to get the Exact right size, but half inch should work great
Old 10-11-2011, 12:21 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
I had to remov my rear seats to recover them in leather. Not too hard but they are cumbersome.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 10-11-2011, 05:26 PM
Electech99's Avatar
Electech99 Electech99 is offline
Vehicle: 2011 Dodge Ram
Electech99 is on a distinguished road
Exactly what I was gonna say. I cut some spacers out of 1/2" wood that were shaped just like the foot on the seat and painted them black. Unless you knew they were there you would never notice it. Fold the seat up then the entire seat would fold down. Worked great and allowed me to mount my amps to my back wall without any problem.
This was on an 07 Big Horn but I'm pretty sure these are no different.
Old 10-14-2011, 04:47 PM
Racerdamon's Avatar
Racerdamon Racerdamon is offline
Vehicle: 2010 Dodge Crew Cab
Rep:145
Racerdamon will become famous soon enoughRacerdamon will become famous soon enough
I cut the 5/8 off the hooks on the back of the seat and it works so good!! had to take the seats out, cut 5/8 off each hook set seat back in and done you can see the seat down in my audio install http://www.ramforumz.com/showthread.php?t=86500
Old 10-14-2011, 10:32 PM
NOLA 5.7 NOLA 5.7 is offline
NOLA 5.7 is on a distinguished road
I curse Dodge every time I have to remove and replace my son's car seat. The same person who designed the headlights (light bulb change) was repsonsible for the rear seats.
Old 10-16-2011, 05:43 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Thanks guys! I have been wishing the back would fold.
Gene
Rear Seat Cover for 1500 Quad Cab jothom122 2010 Dodge Ram Forum 4 07-21-2011 10:28 AM
Replacing rear power window on 2010 LARAMIE382 Body & Interior 24 02-18-2011 10:00 PM
Room for a sub under center front seat? 2010 quad heavyzee Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 01-26-2011 08:38 AM
2010 SLT 3.92 rear 5.7 Hemi ? speed? HKS 2010 Dodge Ram Forum 9 08-03-2010 05:08 PM
2010 leveling by dropping the rear 1 inche. StoneyWV Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 03-27-2010 09:30 PM
