Old 10-10-2011, 11:45 AM
SAVAGERIDER SAVAGERIDER is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: stock
Color: blue
SAVAGERIDER is on a distinguished road
Default Upper Control Arm Tire Rub!
Hey guys. I have a 2001 ram 1500 that I am having trouble with.
I have a set of 285/75R16 (30's) tires mounted to stock rims. My stock tires(as per drivers door sticker) says 245/75R16 as for the overall diameter of the tire, it's unknown to me.
The 1.6 inches of extra tire is rubbing mildly on my upper control arm and the metal is starting to flake off. I am wondering what I need to fix this problem.
I've been looking around and have noticed that different rims have different offsets.
Will I need a + or - offset rim to fix this issue? I also heard wheel spacers may be a solution but cause wheel bearings to wear out prematurely.
Can you suggest steel or cheap alu rims with my reccomeded offset?
Thanks guys for your help, any info would be greatly appreciated!
Cheers!
Old 10-10-2011, 12:42 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
I know that wheel bearings would solve the rubbing problem but I do not know what if any negative effects they have on the truck.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Old 10-10-2011, 12:49 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
You might want to look into some wheel spacers. That would probably be your cheapest alternative.
Old 10-10-2011, 02:05 PM
You won't need a very thick spacer, maybe 1/4". It is true that moving the wheels outboard puts additional strain on the bearings but this isn't that much of a move out.
To avoid rubbing when going with a wider tire (up +2 or more), and you are also getting wheels, you need a bit more negative offset. Depending on how wide the whees and tires go, you might have to go to a +12 or a 0 or even over to the negative side so avoid rubbing.
A lot of tire and wheel shops will measure and/or test fit different combinations so you can make an informed choice.
For now, get some spacers.
Old 10-12-2011, 05:17 PM
Trim Level: stock
Color: blue
Thanks for your help guys!
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 166 01-10-2017 10:03 PM
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 99 05-12-2016 09:55 PM
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 02:52 AM
2002 1500 4x4 upper control arms ddenton Suspension 2 02-22-2012 07:08 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
