Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Kills and More Kills
Kills and More Kills Fictional stories about how you may have smoked another car or truck with your Ram on or off the track! - Keep safe out there!
Old 10-10-2011, 03:26 PM
440ram 440ram is offline
Vehicle: 1988 Dodge LS1 Ram
Rep:36
440ram is on a distinguished road
Default Rematch with a 1999 mustang Cobra
I recently had my 2-3 shift fixed and the truck seems to be running alot better. truck puts down 315 rwhp and 349 rwtq
this is the rematch, looks like I was able to maintain lead for approx 19 sec. from a 20 roll.
This is our same 20 roll race from a few weeks ago. I would hit the limiter on the 2-3 shift at about 75 mph or so and he would catch up my 90 mph
1988 LS1 Dodge Ram
Old 10-10-2011, 09:02 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
I saw your first vid a while back, pretty impressive. You can see the difference, you held on to the lead longer this time. What cam are you running and what gears are you using with those tires? I built a few of those 440's back in my haydays...brings back good mems! A little more torque on the top end may do you some justice. That's pretty good, especially for a big truck againt a mustang...good race. Sounds good too!
Old 10-10-2011, 09:05 PM
RadioFlyer's Avatar
Rep:146
So what are you guys a/f mix at wot, are you monitoring them?
Old 10-10-2011, 11:31 PM
Rep:36
Its a 1998 346cu.in Ls1 with a stock heads/cam setup. It was at 13.8 a/f we tuned it to a 13.0 at WOT.
1988 LS1 Dodge Ram
Old 10-10-2011, 11:33 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Nice run man!!!
Dillon-aka, The Little Kid
Old 10-11-2011, 12:55 AM
Rep:36
it has 3.90 gears and the tires measure 29in.
1988 LS1 Dodge Ram
Old 10-11-2011, 02:46 AM
RadioFlyer's Avatar
Rep:146
Hey that's cool, I like that! Sounds like you've got it pretty much dialed in too...wow!
Old 10-11-2011, 02:44 PM
Rep:36
Thanks, as of now I feel like the truck should run 13's but a trip to the track will only tell. I need to work on the suspention a little more...sometimes I get wheel hop, sometimes I only get one tire spinning, and the front is kinda squirly. I found a bad tie rod, both front u-joints are bad, and I think the front wheel bearing is a tad loose. both front rotors are warped.....,,,,it goes on and on...but one thing at a time and soon it will be a smooth ridding truck as well.
1988 LS1 Dodge Ram
Old 10-11-2011, 03:32 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That is pretty impressive for a stock head/cam LS1. More details please?
Quick truck, good luck on the 13's, I don't know though, my friends 3,300ish lb late LS1 camaro with the better intake manifold, headers and exhaust, ram air only runs a 13.0.
EDIT: Never mind I thought you said 13.0.......breaking into the 13's seems doable!
Sean
Old 10-11-2011, 08:49 PM
Rep:36
Thats what I thought, I was expecting MAYBE 290hp to the tires....
It is a Stock heads/cam LS1 from a 1998 corvette, If I remember right the cam is one of the smaller LS1 cams.....479/.467 lift if I remenber right.
The truck ran a 14.0 @ 94 mph before a few small changes, but at the time had 3.90 gears, stock 4l60e with a sloppy 2-3 shift, ported oem throttle body, headers, flowmaster muffler, and custon home made intake
Since that 14.0 pass I added a UD pulley(maybe 5 rwhp) LS6 intake manifold(maybe 8 rwhp) fixed the 2-3 shift by rebuilding the 4l60e with the high rpm pump spring kit. and the dyno tune of coarse(15hp) I would think It will hit 13.7 or so with the same conditions as the 14.0 run...Again on the 14.0 run I would feel the truck slow down/bind up on the 2-3 shift...now it is a nice quick kick into third with ZERO hesitation.
The 3.90 gears help my truck alot, I think the good combo of bolt-ons help this stock motor show its potential.
1988 LS1 Dodge Ram
Would you believe it? The Ram wins over the mustang! GreatTiger Newbie Checkin! 14 02-27-2011 06:24 PM
Oil filters by Brand & Manufacturer GTyankee Oil Change 10 04-08-2010 12:34 AM
Challenger to face off against Camaro and Mustang on Sunday 1970 Charger Automotive Industry News and Dodge Press Releases 22 11-13-2009 11:08 AM
