Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-10-2011, 02:50 PM
firerescuedodge23's Avatar
firerescuedodge23 firerescuedodge23 is offline
Vehicle: 2007 Dodge Ram1500
Trim Level: SLT (ThunderRoad)
Color: Gold
Rep:59
firerescuedodge23 will become famous soon enough
Default 07 1500 clears 35's with 4 inch lift?
You think a 4 inch lift will clear some 35s on 20inch rims?
AFE Stage 1 intake, Flowmaster 40 series exhaust, Fabtech 6 inch lift, 3 inch PA body lift, 35x12.5x20 Federal Couragia M/t, Full audio system, LSD, HIDs, Superchips Cortex, 20x10 XD Strike -24 offset
Old 10-10-2011, 11:57 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Height wise, shouldn't be a problem. Width? Depends on how wide you plan to go... Might post up some tire sizes you have been pondering. That would give everyone a better idea on whether to confirm they'll work or not.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 10-11-2011, 10:07 AM
Color: Gold
Rep:59
I was gonna go with a 35 12.50 on a 20in wheel and then get some wheel spacers for sure untill i can get some rims and do a little shaving if neccessary
Old 10-13-2011, 02:15 AM
SYDOCK's Avatar
SYDOCK SYDOCK is offline
Vehicle: 2014 Ram
SYDOCK is on a distinguished road
I will try and get some pics, but my current set up is 35/12.50/20 dick cepek mud countrys on kmc monsters. Just a leveling kit no lift, Little bit of rub at full lock.
They would make a loud rubbing noise when I had the stock dodge mud flaps on because they kind of flare out their not smooth so I bought some smooth ones, their smaller but now it just slides on them doesnt make any noise where the lugs caught on the stock mudflaps.
My rims are 20x10 with a -12 offset. I have no issues clearing anywhere else
Lvld,20''Monsters,35''Mudgrapplers,50Cal stub,Trifecta,Tint,3.92LSD,Cabinfilter mod,42''led,6kHID
Old 10-13-2011, 03:16 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
While it won't be any time soon, I would like to do a 4 inch lift and run 35x12.5 with the stock 20s as well. I have done a lot of research and reading and according to everything I have seen it should be no problem.
Check out the fitment info on level kits, 4 inch lifts, and 6 inch lifts at the bottom of this page.
http://www.superlift.com/Catalog.asp?V=140&P=40002
Old 10-13-2011, 02:57 PM
SYDOCK's Avatar
Vehicle: 2014 Ram
If the 4 inch will be anything like the stock upper control arm, you will need spacers or offset rims or the 12.5 tire will rub near the upper ball joint
Old 10-22-2011, 12:10 AM
bigram510 bigram510 is offline
Vehicle: 2006 ram 1500 5.7 hemi
Trim Level: big horn edition
Rep:36
bigram510 is on a distinguished road
i just put 35x12.5x20 tires on my 06 2wd and all i have is a 2.5 leveling kit, was kinda sceptic at first but vey little to no rubbing on full lock turns only
Old 08-30-2012, 12:38 AM
Whitelightningram345 Whitelightningram345 is offline
Vehicle: 2004 dodge ram 1500 slt hem
Whitelightningram345 is on a distinguished road
Default reply
dont know about 20s with 35s but i do know that i was running a 35/12.50-17 mud terrain tire on an offset aftermarket rim with no spacer, dont know the offset of the wheel but they didnt scrub at all and looked great on the truck no rubbin even at full turn and all my dodge has on it is the 2.5in leveling kit on an 04 dodge ram 1500
Last edited by Whitelightningram345; 08-30-2012 at 12:39 AM. Reason: left something out
2011 1500 SLT 4 X 4 Lift toothpick Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 31 05-12-2011 04:40 PM
2010 Dodge 4x4 RAM 1500 Sport Lift... srhamy 2010 Dodge Ram Forum 1 05-03-2011 12:12 PM
Factory installed LIFT KIT?? 1999 1500 4X4 ARMedNBangin Dodge Ram 4x4 - Offroad Discussion 8 03-25-2011 07:29 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
2005 ram 1500 qc/sb body lift on a 03.. 4doordodge4life Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 11-02-2009 09:34 PM
