Dodge Ram Decals
Old 10-16-2011, 10:45 PM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
TPS....throttle position sensor. It is a sensor that is on the side of the throttle body that is held in place by 2 torx bit screws. You simply unplug the wire harness by squeezing the bottom and take out the screws. Put the new one in place and reverse the order. Takes about 10 min tops.
Could save you a ton of money.
Old 10-16-2011, 11:28 PM
hemiram21's Avatar
hemiram21 hemiram21 is offline
Vehicle: 2004 dodge ram 1500
hemiram21 is on a distinguished road
i thought the tps couldnt be changed on a 5.7?
Old 10-17-2011, 12:02 AM
Rammin's Avatar
Rep:44
Not sure about the Hemi buddy.
You know you're in the 4.7 liter section right?
Old 10-17-2011, 12:07 AM
hemiram21's Avatar
Yea lol just seeing if there was a solution because my truck is doing the same thing as others
Old 10-17-2011, 12:11 AM
Rammin's Avatar
Rep:44
Haha sorry man. If I knew I would help but I'm not sure about the Hemi.
Good luck though!
Old 10-26-2014, 09:14 AM
PuroPinchePedo
Hi, glad I found this post. I have the same issue with my 07 Dodge Ram. After running a diagnostic we confirmed my TPS is bad. A mechanic told me after it's replaced my truck would need to be reprogrammed. Is that true? I saw a video online where a guy just unplug the old one and put in the new one. Also, what's the best brand? Can I just get one from my local parts store or should I go to the dealer for the part?
Old 10-28-2014, 10:14 AM
KelseytheDodgeGirl's Avatar
KelseytheDodgeGirl KelseytheDodgeGirl is offline
Vehicle: 2002 Ram 1500 Reg Cab 2WD
Rep:138
KelseytheDodgeGirl will become famous soon enoughKelseytheDodgeGirl will become famous soon enough
Lightbulb
Could be wrong, but I've never heard of having to reprogram after replacing TPS. As for brand, not so sure. Myself, I'd check prices but lean more towards Mopar parts...
Good luck!
Go Dodge!
1996 Dodge Ram 1500 Laramie 5.2L V8 "The Beast"
2002 Dodge Ram 1500 ST 4.7L V8 "Silver" Build thread
2006 Dodge Ram 1500 Laramie 5.7L V8 Hemi
Old 10-30-2014, 01:19 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
My 03 had the same problems. And note: a bad TPS can cause shifting issues as well. My truck stumbled, had erratic idle, surging at stop lights and would randomly shift in and out of O/D on the freeway. A new TPS fixed all the issues.
Old 11-07-2014, 11:24 PM
AustinPower's Avatar
AustinPower AustinPower is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Color: Grey
AustinPower is on a distinguished road
Yup, mine had the same issue. I could put my truck in Park, and the truck would idle just fine. If I slightly tapped the accelerator, it would then rev up and down and keep doing this till I went into drive mode. Quick easy fix, although I will say I might try the $30 Autozone part next time. Dealer charged $100 for the TPS!!
Old 10-22-2016, 04:07 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Ok, my 2004 4.7 is doing something similar to this. It will idle down to about 500rpm and if you touch the gas it just dies. Also, sometimes it will run great but then the idle will start dropping and the engine acts like there is an electrical strain going on since the altimeter will climb to somewhere around 18-20v. I'm thinking TPS after reading this thread. Should I look at something else?
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Trasmission Help!!! bigjeff64 5.9L V8 Specific Topics 16 03-16-2015 11:49 AM
P1128 p1129 firecadet613 5.7L V8 Specific Topics 9 03-06-2015 02:52 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 06:53 PM
over head console ram man Electrical 1 10-17-2010 01:41 AM
