Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Place your Ad Here!
View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 203 31.92%
No, I have not noticed this problem. 313 49.21%
I can't determine for sure if I have this problem. 120 18.87%
Voters: 636. You may not vote on this poll
Old 12-06-2011, 12:47 AM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Vehicle: 2011 Dodge Ram
Color: Grey
Rep:27
stangd1909 is on a distinguished road
I had mine TC changed out on Friday. Well it's making the noise again, I am dropping it off on again Thursday.
Old 12-06-2011, 01:10 AM
954rrmike's Avatar
954rrmike 954rrmike is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport Crew Cab
954rrmike is on a distinguished road
That is unreal, mine is getting changed on Monday, so is the trans engineer saying the noise will return when the trucks get old.
2014 Sport Crew Cab White,8 speed 392LSD,LineX bed liner, Mufflex DOD24M, 18" xd monsters with blizzaks, weather tech floor liners and mudflaps
Old 12-06-2011, 09:41 AM
Jermsgeek Jermsgeek is offline
Vehicle: 2011 Ram 1500
Trim Level: 4x4 Crew Cab Bighorn
Color: Rugged Brown Pearl
Jermsgeek is on a distinguished road
Got my truck back last night after have the TC replaced yesterday. Drives like a dream now. Noise is completely gone, much of the vibrations are gone, and it seems like it's much more firm when the TC locks up. It always felt like it was hesitating/slipping more that it should have, but you never know. Maybe it's the 'Truck works better because I washed it' syndrome. Very happy it's fixed indeed!
Old 12-06-2011, 10:08 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:501
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
No, this noise is not something that's present in all trucks (or that will be present once they wear in).
The amount of backlash in the turbine hub spline will vary from one part to another. If you get one that has too much backlash, it will be noisy (and will get slightly worse as it wears in). If you get one with acceptable backlash, you will have no noise. As the teeth brinell in, you will only develop the noise if the brinelling takes you from the acceptable range of backlash into the "noisy" range. But since the amount of brinelling is very small (a few thousandths of an inch) I suspect that in most cases, you'll still be in the acceptable range even after the teeth are brinelled.
The replacement converters use a much tighter-fit spline than the original design (it's actually a press fit), so they should have no noise. If you're getting yours replaced, you might want to have them check the barcode label on the new converter to ensure they've got the correct (latest) part. Mopar sells converters as kits (converter plus 4 new bolts), so the Mopar part number for the kit is not the same as the production (barcode) part number. Here is the decoder guide:
4.7L engine: Converter = 04752705AA, Mopar kit = RL051241AB
Most 5.7L engines: Converter = 04736911AB, Mopar kit = RL051146AB
5.7L RT model: Converter = 04736982AB, Mopar kit = RL051167AB
Old 12-06-2011, 11:27 AM
articcatbill articcatbill is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Color: Green
Rep:24
articcatbill is on a distinguished road
Just dropped mine off this AM for a new TC. My dealership has been really great about the whole thing, no problems at all. I asked them to confirm the part number, they pulled the star case up, pulled the part confirmed the revised TC number. Then pulled the VIN up and confirmed again that way with the revised number. Everything matched so I they have the correct TC. I also asked them to check for debris while they are in there.
So I am just hoping mine it one of the success stories.
Old 12-07-2011, 10:49 AM
STRSTALKER STRSTALKER is offline
Vehicle: 2011 DODGE RAM
Trim Level: BIG HORN
Color: WHITE
STRSTALKER is on a distinguished road
3920 miles and my torque converter is ordered and will be replaced as soon as it comes in but ive had the noise since 1100 miles but didn't know of anything until i researhed it and found out it is a major issue
Old 12-07-2011, 06:50 PM
954rrmike's Avatar
Hey Jermsgeek where in NB are you located? Dealer received torque converter #RL051146AB for my 2011 sport. Is this the right part number? Its booked in for Monday.
Old 12-08-2011, 10:14 AM
Vehicle: N/A
Rep:501
YES, that is the correct kit number. You might want to ask them to check the barcode number on the converter in the kit to verify that it is correct. The barcode number should be 04736911AB.
Old 12-08-2011, 10:24 AM
Hi 954rrmike, I'm from Moncton. Can-Am did the TC replacement for me. Nothing but great service from them!
Old 12-08-2011, 12:34 PM
Gatekeepr Gatekeepr is offline
Vehicle: 2011 Dodge Ram 1500 Crew 4x4
Trim Level: High Quality Cloth
Color: White Gold
Gatekeepr is on a distinguished road
Default Torque Converter Rattle starting at 1400 RPM
From Day ONE when the torque converter went into lockup mode (above 35 mph) in 3rd, 4th, 5th gears starting at 1400 rpm under slight excelleration and continuing up past 2000 rpm. It sounded like a bad idler pulley grinding. Quite a loud rattle. As the truck went at highway speeds the road noise almost covered it up. Tow mode made no difference but did make the noise more noticable at lower speeds.
Took it back to the orginal dealer and they told me to turn the radio up as not to hear it. ( I do not listen to the radio ), then they told me it was within their opinion of acceptable. I got ahold of Chrysler Customer Service @ 866 726 4636 and they said to take it to another dealer. I did.
The service tech had no problems hearing my grinding noise. Looked up the problem on a Star Case and found a number that perfectly described my problem Case# S 1121000005. The second dealer changed the TC as per the case number and the noise is gone. Fixed at 2800 miles from new.
I hope this helps those having the simular problems
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 08:38 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 07:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 11:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 11:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 12:04 PM
