View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 194 32.33%
No, I have not noticed this problem. 292 48.67%
I can't determine for sure if I have this problem. 114 19.00%
Voters: 600. You may not vote on this poll
Old 12-09-2011, 01:46 PM
dpeterso dpeterso is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn Quad Cab
Color: Saddle Brown
dpeterso is on a distinguished road
With those of you who had a torque converter replaced, did you here or feel any vibrations when in Tow/Haul mode? I'm not sure If I have the issue or not. I get a growling noise and some vibration around 50mph when MDS kicks in. If I put it in tow/haul it's smooth and no vibration. I'm not sure if it's the engine lugging at the low RPM's in full lockup with MDS or if it's a TC issue. I'm about ready to go down and test drive a 2012 to see if there's a difference.
Old 12-09-2011, 01:56 PM
articcatbill articcatbill is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Color: Green
Rep:24
articcatbill is on a distinguished road
Mine would continue in tow/haul mode. Many said it would get worse, mine was the same either. Sometimes it was harder to get to do it in tow/haul because it would go out of lock-up quicker, but it was definitely there.
In the end before I had mine replaced I could hear it over the radio even when I had it cranked up pretty loud. Nobody with me in the truck missed it. So it was very noticeable. It was especially bad when towing even a light load.
From my experience if it is the TC you will hear it not just feel something.
Old 12-09-2011, 02:04 PM
Jody79 Jody79 is offline
Vehicle: 2011 ram 1500
Trim Level: express
Color: blue
Jody79 is on a distinguished road
Just dropped my truck off at dealer yesterday after they ordered a new TC to install. I will post update once I get it back.
Old 12-09-2011, 02:58 PM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Tow/Haul or normal mode should not make a difference. The TCC will go into full lockup in either case. So if you have the converter warble, you should hear it in Tow/Haul as well as normal driving.
[ Note that this assumes your TCC stays in full lockup when you enter Tow/Haul mode. Since the Tow/Haul shift patterns are different, you may have a situation where the TCC will unlock (or go to partial lock) when you enter Tow/Haul. But if you go into full lockup while in Tow/Haul mode, you should get the same noise. ]
MDS is another story. MDS mode disables full lockup; it only allows partial lock. So you should NOT hear the noise in MDS mode. If you hear a noise in MDS, it's not the converter rattle.
Also, note that ERS mode disables MDS (and thus, re-enables full lockup). So if you're trying to diagnose the converter noise, run at light cruise about 45-50 mph. In normal Drive mode, MDS should kick on and you should have NO noise. Then tap the ERS (-) switch to put the trans in "5" (which is normal 4th gear). At this point, the TCC should engage full lockup, so if the noise is present you should hear it.
But as I said before, this is not a durability concern, so if you only hear the noise when you go hunting for it, you don't really need to bother with getting the converter replaced.
Old 12-10-2011, 08:58 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
TransEngineer - As others have said, thank you for the valuable insight. You feedback has improved numerous conversations on this forum and it is appreciated.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 12-10-2011, 09:43 PM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Color: Grey
Rep:27
stangd1909 is on a distinguished road
Originally Posted by articcatbill View Post
stangd1909 here are the part numbers, depends on your truck:
Parts Required:
AR (1) RL051167AB Kit, Torque Converter
(fits
2009 - 2011 2WD DS R/T Only)
AR (1) RL051146AB Kit, Torque Converter
(fits
2009 4.7L WK/WH/W2/XK/XH,
2009 5.7L DS/DC/DH/D1/HB/HG/WK/WH/W2/XK
2010 5.7L DS/DD/DJ/DX/WK/WH/XK/XH
2011 5.7L DS/DD/DJ/D2 Only)
AR (1) RL0512241AB Kit, Torque Converter
(fits
2008 4.7L 2WD ND/HB/HG/DR/WK/WH/XK/XH
2008 4.7L 4WD WK/WH/XK/XH
2008 5.7L 2WD/4WD DR/HB/HG/WK/WH/XK/XH
2009 4.7L 2WD ND/HB/HG/DS
2010 4.7L 2WD ND/DS/DX
2011 4.7L 2WD DS/DX/ND
2011 5.7L 2WD/4WD WD/WK/W2 Only)
The dealer can also look this up with your vin number. The above came from the star case posted earlier in this thread. I had my dealer confirm the number both with the vin and against the star case number. They told me all the incorrect ones should have been recalled, once they supercede then the dealers have 14 days to return them or they don't get paid.
thanks for the info, rep point headed your way.
Old 12-12-2011, 08:52 PM
Dave532 Dave532 is offline
Vehicle: 2014 2500 Ram
Color: Cherry Red
Rep:18
Dave532 is on a distinguished road
My new torque converter arrived last week Thursday. I dropped the truck off this morning. They gave me a free rental (Caravan) due to the "early failure" of the torque converter. Picked up my truck this afternoon and found the noise gone.
Impressed with:
How quick they diagnosed the issue.
They didn't argue with me at all.
Quick repair.
Problem appears to be solved the first attempt.
Free rental car.
Dissappointed with:
truck was not washed when I picked it up
This all occured at Burnsville Dodge in Minnesota.
-Dave
Originally Posted by Dave532 View Post
I brought my 2011 2500 ST (3800 miles) in to the dealer for (first free) an oil change, squeaky seat and what I described as an exhaust rattle in 4th gear between 1500 and 2000 RPM.
I was aware of the Starz case but I feigned ignorance to gauge how they would react to the noise.
After a test drive, they initiated the Starz case discussion with me and ordered a new torque converter the same day. I was impressed.
I noticed the noise around 3000 miles but it was very subdued and there was no associated vibration.
Since new, my truck is daily driven, has towed 3 cars less than 500 miles total. Build month is June.
-Dave532
Old 12-12-2011, 10:37 PM
954rrmike's Avatar
954rrmike 954rrmike is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport Crew Cab
954rrmike is on a distinguished road
Ming got fixed today. The noise is gone. I am a licensed tech so I had to double check the job that was done on my baby. Everything looks good but I checked the transfer case fluid and it was about 1/2 inch below the fill hole. I want to fill it and the fluid was red, its a borgwarner transfer case that has auto mode in my 2011 sport so is the fluid atf 4. How do you know if I have the NVG246 transfer case?
2014 Sport Crew Cab White,8 speed 392LSD,LineX bed liner, Mufflex DOD24M, 18" xd monsters with blizzaks, weather tech floor liners and mudflaps
Old 12-13-2011, 11:00 AM
HenryG's Avatar
HenryG HenryG is offline
Color: Grey
Rep:17
HenryG is on a distinguished road
How loud is the noise with a bad Torque converter. I hear something every once in a while but can't determine if it is the TC. The noise that I have is just slightly louder than the exhaust note and a little higher pitch and very intermittent. Thoughts?? Dealer flashed the rig at 3000 mile oil change, no noticeable change in anything after that. Why was that the magic answer???
Old 12-13-2011, 02:16 PM
954rrmike's Avatar
Mine was bad in to haul mode around 40mph between 1200-2000 rpm light throttle. You had to listen for it but its not there now with the new converter. If the transengineer reads this can you tell me what my 2011 sport with a Borg Warner transfer case takes for fluid. Thanks
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 07:38 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 06:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 10:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 10:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 12:04 PM
