View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 200 32.31%
No, I have not noticed this problem. 302 48.79%
I can't determine for sure if I have this problem. 117 18.90%
Voters: 619. You may not vote on this poll
Old 06-18-2012, 10:16 PM
chris15005's Avatar
chris15005 chris15005 is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: Bright Silver / Black two tone
chris15005 is on a distinguished road
Just found this thread my 2012 Express is getting a new torque converter as we speak it lasted 300 miles and one week of ownership. My truck was stalling when you put it in gear basically going into lockup as soon as it went into gear and killing the motor i did have the grinding as well.
Old 06-19-2012, 08:15 AM
Blackthunder's Avatar
Blackthunder Blackthunder is offline
Vehicle: 2011 Dodge Ram 2500 HD
Blackthunder is on a distinguished road
Hmmm....Chrysler still hasn't figured it out yet?
Old 06-19-2012, 08:43 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:414
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
The warble noise was fixed for 2012 MY. The stalling problem is a separate issue, and if the converter replacement fixes it, then it was due to an internal converter defect.
Old 06-20-2012, 09:29 PM
turbo dragon turbo dragon is offline
Vehicle: 2014 Ram 1500 4x4
Color: silver
turbo dragon is on a distinguished road
I guess thats a NO!!!
Old 06-24-2012, 10:31 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
I remember the very first 2011 dodge ram I got in the shop for this. the guy said that at 45mph if you feathered the throttle there was a very faint grinding/rattle noise. For the life of me I could not figure it out. Turns out there was actually a Chrysler STAR (help center) case on this that said to replace the torque converter. I did it and the noise was gone. Since then I've done at least 10 of these. Not sure why Chrysler never made a TSB about it.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 06-26-2012, 08:26 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
Took mine in yesterday (26K miles) to have them look at a "bump along" shifting issue and the torque converter "rattle". They ordered a new torque converter and said they should be able to solve the "bump along" issue with software.
Waiting to get my truck back. We will see.
Old 06-27-2012, 02:15 PM
thiggins's Avatar
Rep:44
Follow up:
Got the truck back yesterday. They did TSB 18-011-12, and so far I'm pretty happy with the results. Evidently it reprograms LOTS of things performance related. Shifting makes more sense now, downshifting is better, etc,...
In talking with their transmission guy, he said Chrysler is doing this TSB instead of replacing the torque converters. We will see if the TC noise is really gone. I'll be doing a bunch of towing very soon.
Here's the TSB:
NUMBER: 18-011-12
GROUP: Vehicle Performance
DATE: March 15, 2012
SUBJECT:
Flash: MIL Illumination With Transmission And Driveability Improvements
OVERVIEW:
This bulletin involves flash reprogramming the Powertrain Control Module (PCM) with new
software.
MODELS:
2009 (HB) Durango
2009 (HG) Aspen
2010 (DJ) Ram 2500 Pickup
2009 - 2010 (DS) Ram 1500 Pickup
2009 - 2010 (DH) Ram 2500 Pickup
2009 - 2010 (DC) Ram 3500 Cab Chassis
2009 - 2010 (ND) Dakota
NOTE: This Service Bulletin applies to HB/HG/DJ/DS/DH/DC/ND vehicles equipped
with a 3.7L, 4.7L or 5.7L engine (Sales Code EKG, EVE, EZC, EZD or EZH) and
a 4 speed 42RLE or 5 speed 545RFE or 6 speed 68RFE automatic
transmission (Sales Code DGV, DGQ or DG7).
SYMPTOM/CONDITION:
The customer may experience a Malfunction Indicator Lamp (MIL) illumination. Upon
further investigation the Technician may find that any of the following Diagnostic Trouble
Codes (DTC's) have been set.
i. P050D - Cold Start Rough Idle
ii. P2181 - Cooling System Performance has been set
iii. P0935 - Line Pressure Sensor Circuit High All RFE transmissions
iv. P0300 through P0308 - Multiple and Single Cylinder Misfire. This condition can
occur when the vehicle is started cold and the driver immediately places vehicle in
drive and applies heavy throttle.
Driveability and Transmission improvements are also included with this software
release. These changes consist of the following:
a. Enhanced clutch protection for more robust torque management during repeated
fore and aft movement (rocking vehicle) all engines.
b. A revised torque convertor lockup schedule that will reduce transmission
temperatures in Tow/Cruise mode All models equipped with RFE transmission.
c. A Clunk sound or feel a shudder when the cruise control resume switch is pressed.
This condition is most noticeable after the brakes were pressed to cancel cruise
control and then the resume switch is pressed All models equipped with RFE
transmission.
d. A shudder or shaking feeling when a wide open throttle (WOT) event is performed
by the customer. This is most noticeable after the transmission downshifts during the
WOT event. This condition will stop once the transmission upshifts All models
e. A shudder or shaking feeling when accelerating from a stop under moderate throttle.
This condition will stop once the transmission upshifts All models equipped with
RFE transmission.
f. A shudder or shaking feeling after the transmission downshifts. This condition will
stop once the RPM's drops All models equipped with RFE transmission.
g. Harsh or noisy natural to reverse shiftsAll models equipped with RFE
transmission.
h. Harsh 4-3 downshifts. This condition happens when there is no throttle applied and
the vehicle is coasting down.All models equipped with RFE transmission.
i. Harsh 1-2 upshifts. This condition happens under moderate or heavy throttle
conditions All models equipped with RFE transmission.
j. Engine knock condition. This condition could happen when a wide open throttle
(WOT) event is performed or cruising at 5400 RPM or above All models equipped
k. Hard start or long crank condition at 0° F (-17° C).all 5.7L DS and DJ models
Reprogramming the PCM will correct the DTC conditions listed above
Old 07-16-2012, 01:26 PM
WeBeDel WeBeDel is offline
WeBeDel is on a distinguished road
I have 48K on my 2011 and have no problems that I am aware of. The only thing that I have noticed is a minor vibration at 50 +/- mph. It seems that around this speed the trans is just not sure if it wants to shift down or not.
Old 07-29-2012, 07:41 PM
RogueRam RogueRam is offline
Vehicle: 2011 1500 Bighorn crew 4x4
Trim Level: Bighorn
Color: Charcoal
RogueRam is on a distinguished road
I get the same at 50-55 especially if i start going up an incline. Wish she would downshift more often and quicker.
Old 08-07-2012, 01:22 PM
PA RAM PA RAM is offline
Vehicle: 2012 ram express
Trim Level: express
PA RAM is on a distinguished road
so after reading, this has been fixed on 2012 build dates?
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 08:38 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 07:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 11:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 11:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 01:04 PM
