View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 191 32.32%
No, I have not noticed this problem. 287 48.56%
I can't determine for sure if I have this problem. 113 19.12%
Voters: 591. You may not vote on this poll
Old 10-02-2012, 09:31 AM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Heard the noise this morning so apparently the RRT for the drivetrain did not help. But at least they tried. Looks like it will be going back to the dealer.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 10-09-2012, 08:03 PM
Dodge20's Avatar
Dodge20 Dodge20 is offline
Color: Mineral Gray
Rep:21
Dodge20 is on a distinguished road
Hi All, figured I'd weigh in on my experience with this. In May I traded in my 2002 Ram 1500 that had given me 11+ years of great service for a 2010 Big Horn Hemi. Due to the great summer up here in the northeast, I spent most of my time on two wheels. On the times that I did drive the truck and on a trip to Cincinnati, I noticed what seemed to sound like a rattling at certain speeds/RPM's, and also when under load (heard it while I was hauling a cord of firewood). It sounded like a loose heat shield or some kind of pre ignition (knocking/pinging) coming from the rear.
A few days later while I was at the dealer for the leaking third brake light seal, I figured I would ask the service writer (not the one I usually have dealt with the past 10 years) about the noise and he said they would have a tech drive with me. Well we were barely out of the lot when he told me it was a normal noise coming from MDS mode and nothing could be done. The writer also said he had a 4th generation Ram with the same noise.
Not satisfied that the irritating noise was "normal", I went to work on the forum here and found the Star Case for the TC. It listed exactly what I was experiencing. I printed out a copy and called the tech writer I normally deal with and told him about the Star Case and he said to come in at my convenience and we would test ride with a transmission tech. I did and the tranny guy heard the noise and ordered the TC which was put in yesterday. I'm happy to say that I noticed immediately that the noise was gone. I drove it a good hour and tried all the methods that caused it before but it's not there. What a relief to have that Ram ride back.
I just wanted to say thanks to all who post here with info like the Star Case. I believe having that in hand made getting the problem fixed that much easier.
Old 10-15-2012, 07:37 PM
18hpx 18hpx is offline
Vehicle: 2011 dodge ram slt quad
18hpx is on a distinguished road
Default courtesy dodge in brandon Fl said trans was normal
I had my 2011 Dodge Ram for 11 months .It was at Courtesy Dodge in Brandon for two days they said nothing was wrong with the transmission .I drove the truck down the street and traded it in on a new Frontier. That was the worste customer service I ever seen ,I took a giant loss trading in a year on truck that I replaced wheels,grill, lower suspension,added bed cover, It was the first and last Dodge thatI will ever buy.
Joe R
Old 10-15-2012, 10:18 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
So you traded it in because one dealer didn't know what they were doing? That makes no sense. Should've gone to another dealer
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 10-15-2012, 11:12 PM
sself510 sself510 is offline
Vehicle: 2009 Dodge Ram 1500 Sport
sself510 is on a distinguished road
I also have the torque converter issue, but it didnt come about until I upgraded my torque converter to a circle d 3000-3200 stall. once upgraded there was a grinding like noise, more or less like a really loud locust sounding noise coming from my transmission.
Also after changing the torque converter I have trouble reaching the stall from a dead stop at wide open throttle, and while braking and giving it throttle at the same time. It is almost like the computer doesnt like the high stall and will not allow it to reach the stall unless I am already moving.
I am not sure how to fix either problem, but would be interested in figuring out a solution for both problems. If anyone knows how to fix the higher stall issue I think i can live with the locust like noise.
Old 10-16-2012, 12:50 AM
garner's Avatar
Rep:46
Your issues have nothing to do with the factory issue. Yours is due to something being wrong with your aftermarket one. Contact circle d and they should get it figured out
Old 10-16-2012, 12:57 AM
well i put the factory converter back on and it continues to make the noise now. i suspected it was the converter too, but now that it continues to do it im not so sure.
Old 10-16-2012, 09:21 AM
snrusnak's Avatar
snrusnak snrusnak is online now
Rep:1385
You installed the converter yourself? Are you sure you had it fully seated onto the oil pump?
Sean
Old 10-16-2012, 09:35 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:355
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
... Also after changing the torque converter I have trouble reaching the stall from a dead stop at wide open throttle, and while braking and giving it throttle at the same time. It is almost like the computer doesnt like the high stall and will not allow it to reach the stall unless I am already moving. ...
Yes, the computer IS holding back your torque. We have two different stall torque limits (which limit the engine torque in 1st gear): one for when the brakes are applied, and one for when the brakes are released. So there will be a difference depending on whether your brakes are applied or not.
Old 10-16-2012, 11:53 PM
TheSatinPumpkin's Avatar
TheSatinPumpkin TheSatinPumpkin is online now
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Joe R
Sweet....welcome
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 7 10-03-2011 11:10 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 07:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 11:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 11:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 01:04 PM
