Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 203 31.92%
No, I have not noticed this problem. 313 49.21%
I can't determine for sure if I have this problem. 120 18.87%
Voters: 636. You may not vote on this poll
Old 03-12-2014, 07:43 PM
14bluelaramie 14bluelaramie is offline
Vehicle: 2014 ram 1500
Trim Level: laramie
Color: blue streak pearl
14bluelaramie is on a distinguished road
I have a 2014 ram 1500 Laramie 4x4 and I get a vibration at 2000/2100 rpms. it has 1400 miles on it and has been doing this since new. I called dealer and service advisory told me they had a 2014 ram 1500 I previous week and they determined it is the characteristic of the truck. I am not buying it. need some help please!!!
Old 03-13-2014, 07:15 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:491
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Do you have the 8-speed trans?
This thread relates to a T/C noise issue that was present on 2010-2011 trucks with 6-speed trans. That issue was fixed effective with 2012 MY.
I believe there is a thread in the 2014 forum concerning the noise / vibration at ~2000 RPM. I don't have an answer on the cause (or cure) of that particular issue, but you might want to post in that thread instead.
Old 03-24-2014, 05:54 PM
CDNtbone303's Avatar
CDNtbone303 CDNtbone303 is offline
Trim Level: Bighorn
Color: Bright Metallic Silver
CDNtbone303 is on a distinguished road
I hear a noise coming from the right passenger side of the engine when the MDS/eco light is wanting to come on and when in eco mode when the engine is forcing like going up a small hill I get a lot of vibrations untill 8 cylinders kick in then it's smooth. Does this sound like the converter issue or just the MDS?
Old 03-24-2014, 06:50 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:762
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
mds causes our engines to lug a bit, sounds like that is what is happening to your truck.
Old 04-17-2014, 08:59 PM
Manshoon Manshoon is offline
Vehicle: 2011 Ram 1500 Laramie Longhorn
Trim Level: Longhorn
Color: 2 Tone brown
Manshoon is on a distinguished road
This is what my truck was doing when it was new also, in eco mode, grinding clunky sound like something dragging under the Pass. side of the truck. This started at 1200 miles and the dealer replaced my Torque converter after taking it in.
Old 04-25-2014, 03:19 AM
mekaw mekaw is offline
Vehicle: 2010 ram 1500 sport crew
Rep:35
mekaw is on a distinguished road
did anyone ever had TC replaced on second hand Ram?
I know powertrain warranty is valid until 100k whether you are the original owner or not but more or so how dealer would take it if you bought the truck at a non dodge dealer.
my 2010 sport is sitting at 91K km and I hear the noise but not sure how helpful dodge dealers are going to be on a vehicle that was not bought from them.
Old 04-29-2014, 10:06 PM
Airportff Airportff is offline
Color: Black Pearl
Airportff is on a distinguished road
I'm glad I found this thread. I picked up mu 2011 last week and while driving in to work on Sunday I noticed a noise and very slight vibration at around 1500 rpm. If I feather the throttle I can get it to come and go. But it is constant in that rpm range at about 30-45mph
Does this sound like the TC issues discussed in this thread?
Old 04-30-2014, 10:35 AM
articcatbill articcatbill is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Color: Green
Rep:24
articcatbill is on a distinguished road
It does sound like it, it is a long thread but is you read through it some people characterized the noise like a frisbee scraping across concrete. That was what mine sounded like. I could also definitely make mine create the noise. Had the TC replaced been good ever since.
Old 05-01-2014, 10:03 PM
Color: Black Pearl
Have an appointment with the dealer in the morning to get it checked out. We shall see.
Old 05-05-2014, 05:46 PM
bluedodgeram's Avatar
bluedodgeram bluedodgeram is offline
Vehicle: 2011 Ram Sport 4X4 Crew Cab
Color: Deep water blue pearl
Rep:13
bluedodgeram is on a distinguished road
Hi Airportff, I am experiencing exactly what your experiencing. Did the dealer find out what was wrong? Or did they tell you it was normal? Is there and update, or TSB to the Shudder on light throttle to maintain 70 kms per hr? Supposedly it is a known issue, any updates of fixes yet? TCC and MDS shudder at the same time causes shudder under light throttle application at around 70 kms/hr, anyone? I found this post in the Dodge talk forum, anyone have similar symptoms?
[IMG]http://www.*********.com/forums/images/misc/ramright2.gif[/IMG]
Registered User
Joined: Jul 2003Posts: 19City: CincinnatiState: OHStatus: Online
Post #1
I started this threat here (http://***************/forum/4th-gen-...own-issue.html) under "Getting some drivetrain vibrations" but decided I should start a new one tiled better to reflect the issue - to better help anyone else searching or having this issue
In essence at specific points in acceleration, usually the mid and near shift points, I get vibrations. Giving steady slight gas (like driving at steady speed in traffic), then accelerate a little I'm getting noticeable vibrations.
So took it dealer several times and after invoking Dodge resolution group, the service manager who was very helpful, and 5 start master tech team dealers call, I got a final statement.
They said "This shutter is a known issue and is caused by the MDS and TCC (torque converter control) activating at the same time. We are aware of the widely reported problem but have no resolution available at this time."
Two options: gun it and drive fast all the time or learn to live with a shutter/droan in your $30,000 truck.
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 08:38 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 07:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 11:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 11:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 12:04 PM
