Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Place your Ad Here!
View Poll Results: Have you experienced the torque converter problem?
Yes, I had this problem and had or plan to have it fixed. 203 31.92%
No, I have not noticed this problem. 313 49.21%
I can't determine for sure if I have this problem. 120 18.87%
Voters: 636. You may not vote on this poll
Old 05-05-2014, 10:48 PM
Airportff Airportff is offline
Vehicle: 2011 Ram 1500
Color: Black Pearl
Airportff is on a distinguished road
They said it was normal. The tech took it for a ride then came back and picked me up and let me drive it. Just to make sure that what he heard was what I was talking about. He said that it was fine and it was the TC locking up. Just doesn't sound right to me. I have a friend from high school that is a service manager at another dealership. I'm going to try to swing by there near the end of the week.
Old 05-30-2014, 10:33 AM
HammerHead's Avatar
HammerHead HammerHead is offline
Vehicle: Ram 1500
Rep:20
HammerHead is on a distinguished road
Originally Posted by Razorbass View Post
If you have a 4th gen Ram (2009-present) and either have or have not had an issue with the reported grinding noise, please vote in the poll. My intent is to see how widespread this issue is among forum members.
As for me, I can tell for sure because my Magnaflow cat back exhaust upgrade is the dominant noise I hear (when my radio is not blaring). So I am having a hard time determining if I have this issue.
No grinding noise for me
Only 16K on my new girl..
Geared-Tuned 0-60 in 4.82
Proud member of the 4 second club...
Old 05-30-2014, 11:09 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
42,000 kms now and no sign of any TC problems.
sales@revelperformance.com
Old 06-22-2014, 01:13 PM
Hemi1500 Hemi1500 is offline
Trim Level: SLT Big Horn
Hemi1500 is on a distinguished road
Hmm... I have this noise, starts around 1400-1500 RPM at very light throttle. If I downshift, it goes away; if I let off the throttle, it goes away. With the issue I have with the 4wd shifting on its own, I thought it was the front diff or transfer case, but it doesn't necessarily correspond to the 4wd flaking out. So now I wonder... I don't notice any difference in how the truck drives while it's making the noise, but I should probably have this checked out once the 4wd issue is fixed.
Old 11-23-2014, 11:37 PM
canadianEH266 canadianEH266 is offline
Vehicle: 2015 Ram 2500 Power Wagon
Trim Level: Power Wagon
Color: Maximum Steel
canadianEH266 is on a distinguished road
I had my TC bolts come loose and caused a serious rattling grinding noise when I pressed on the gas pedal (of course) at lower rpm. Drove it right to the dealer and they new right away what the problem was after I described what was going on lol. This happened under 20,000km. Been good ever since.
Old 06-01-2015, 08:52 AM
StevePG's Avatar
StevePG StevePG is offline
Vehicle: 2011 Ram 1500 Crew Cab
Trim Level: Outdoorsman
Rep:22
StevePG is on a distinguished road
Send a message via AIM to StevePG
Do you also hear this noise at idle? I had a mechanic buddy of mine listen to it on a test ride. Both he and one of his employees immediately said it was a catalytic converter going bad. I hear it on acceleration and at idle.
Old 11-05-2015, 09:09 AM
streetHEMI streetHEMI is offline
Vehicle: 2011 dodge ram
Color: blue
streetHEMI is on a distinguished road
Originally Posted by garner View Post
About the part I bolded, the reason the rpm isn't dropping much is because when you shift to 3 as shown on the display you're actually going into second prime which is a gear to bridge the large gap between 2nd and 3rd. So on the display 1=1st, 2=2nd, 3=2nd prime, 4=3rd, 5=4th, and then shifting back into drive puts you in 5th
That makes perfect sense, thanks
blue hot rod-2011 dodge ram 1500 slt-2wd- 5speed, hemi and open diff and its a crew cab short bed 15.3 @92 in the quarter (before tuning)
Mods- K&N drop in-knockoff magnaflow 18" dialbo intune I2 HF 93 tune
Old 12-08-2015, 04:41 PM
ken1973 ken1973 is offline
Color: silver
ken1973 is on a distinguished road
Default TC problem
My 2011 ram 1500 5.7l has every symptom of a bad tc. this truck is not under warranty. Is this a problem that dodge did a recall on? What was the cost of replacement? And has the replacement tc been changed or will I be having the same problem going forward. Thanks
Old 12-08-2015, 06:27 PM
dblj1500 dblj1500 is offline
Vehicle: 2012 Ram
Trim Level: Ram 1500, ST
dblj1500 is on a distinguished road
2012, 27,500 miles and no problem yet.
Old 03-05-2016, 12:29 AM
Universalshaman Universalshaman is offline
Vehicle: 2011 Dodge Ram
Color: Metallic Black
Universalshaman is on a distinguished road
2011, 5 speed transmission 5.7, 106,000kms... no issues yet..
Had a PCM update for the MDS drone, worked like magic, no more low hum when the Eco light turns on.
How To, Remove Transmission and Torque Converter moparornocar72 Dodge Ram Knowledge Base 8 01-26-2015 08:38 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 07:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 11:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 11:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 12:04 PM
