Front axle help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-10-2011, 10:45 PM
lienhart06 lienhart06 is offline
lienhart06 is on a distinguished road
Default Front axle help
my 1997 dodge ram 4x4 1500, i recently changed my hub and when i pulled of the spindle nut, it was completely cross-threaded, im talking almost completely smooth. i was wondering can i buy just the last part of the axle that goes in the hub instead of the whole axle. Im trying to save money with this. I caked it with JB weld but i dont think it will hold. Thanks for help.
Old 10-11-2011, 11:40 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
should be able to since if you change the axle joint you gotta remove it
Old 10-11-2011, 09:27 PM
Trouble's Avatar
Trouble Trouble is offline
Vehicle: 1997 ram 1500
Color: red over silver
Trouble is on a distinguished road
http://www.ringpinion.com/PartsList....-+Front+Outer+
Old 10-11-2011, 09:41 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
sounds like an ebay thing to me, I think the axle stub is the same left or right, last time I bought an axle joint it was around 20 dollars, it does NOT pay to buy the joint with the grease joint, put your own in with a #7 drill bit and a 1/4x28 (NF) tap, I prefer my grease fittings in an end cap. if the joint with the fitting won't rotate, put a setscrew in the hole when you aren't greasing it, for the frequency of greasing an axle joint, it doesn't hurt to remove the setscrew and stick a fitting in there and replacing it when lubed up. You should be able to pick up a 1 11/16 deep socket on ebay cheap, and thin the wall a little if necessary with a grinder. The nut should be available either on ebay or at a scrapyard, you'd be most fortunate to pick up just the stub at a scrapyard tho, they'd probably want to sell you the entire shaft assy, or worse yet, the entire axle unit... Good luck!!
Old 10-19-2011, 01:16 AM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
you need a stub shaft wheel joint and nut all available at orielly's, the one here keeps them on the shelf all the time. Last time I bought all three it can to about 150 bucks if I remember right. Next time you have to take one apart make you remove the cotter pin and use a little heat and some PB Blast, kroil, liquid wrench or the like.
Ram 2500 Straight front axle history sqdqo LD RAM - General Discussion 4 09-02-2011 08:54 PM
Axle nut size on front end '10 1500 doz 2010 Dodge Ram Forum 2 08-13-2011 10:46 PM
Front Axle Question tomcatg Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 10-25-2010 08:27 PM
2004 2500 4x4 front axle and wheel fitment??????? rustyolred Dodge Ram Wheels And Tires 1 06-30-2010 07:22 PM
Front Axle leak info gregster 2010 Dodge Ram Forum 10 03-09-2010 03:10 PM
