Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-11-2011, 08:58 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default catch can vs pcv
Hi
Ive been a member of this forum for about 2 years but this is my first time posting
I have a 2009 ram sport crew cab with ram box, up to now i have a predator on it, i have receive my 24 mufflex and knn CAI this morning but not yet install
My question is probally simple for most of you
I would like to install a catch can wich will collect overflow oil from pcv
Is it possible to just put a plug instead of the valve
sorry for this dumb question but i was wondering
Pascal
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 10-11-2011, 09:38 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm not sure what you mean by just put a plug instead of a valve....
If you mean just plug the valve cover instead of having a pcv valve then no you can't do this it will cause leaks/blown seals and gaskets in your engine from the pressure buildup.
If you mean that when you install the catch can, can you just use an open fitting in place of the pcv valve, you could, although it may not directly fit properly, and there's no reason to do this. The valve will help keep the oil in the engine, and the pressure out, if there's no valve you may get more oil going to the catch can... The pcv valve is very inexpensive, and usually only needs replaced around every 100k miles or so. I like to take mine off every 50k miles and soak it in dawn dish soap/water to break down the oil/grease to clean it up to try to keep it from sticking. At 100k miles, for the few bucks to replace it it's cheap security to keep pressure out of your engine.
Sean
Old 10-11-2011, 10:27 AM
crusher's Avatar
Rep:363
Thanks for the help
I did mean a plug direct in the valve cover
because a few years back i believe if i remember right that i saw a plug that look like a very mini air filter for the valve cover for mustang and others cars so i was wondering if that would do the job
Old 10-11-2011, 10:33 AM
snrusnak's Avatar
Rep:1385
Thanks for the help
Well everybody has an opinion....many people do use those mini filters, and say they don't have any issues. I personally don't use them(have tried them in the past). When I used them I ended up with a rear main crank seal oil leak each time only a few hundred miles later... Whatever you do, don't literally "plug" it up, at least have a filter for it to breath out of. I would suggest doing the catch can, but the mini filters work for other people, they basically do the same job, I just don't think they breathe enough, I feel they are too restrictive and hold too much pressure in... Also, the stock pcv setup will breather better than the mini filters, but won't keep the engine clean.
Stock pcv setup_________breathes well, dirty intake
Mini filters______________clean intake, breathes ok(debatable)
Catch can______________breathes well and keeps intake clean *winner*
Sean
Old 10-11-2011, 10:45 AM
crusher's Avatar
Rep:363
your right
at the price of the truck i will go safe
i'll be shopping for a catch can today ...
thank's again for the info and help
Old 10-11-2011, 10:49 AM
snrusnak's Avatar
Rep:1385
No problem. I think there's a brand that has some scratch and dent one's for sell, I think the name is bully dog, or something like that. It's about $100 for everything. They are similar to the Billet Technology ones, I've also found some others through google and ebay that are nice and about $90-$100.
Post back once you do the install.
Sean
Old 10-11-2011, 11:35 AM
moparornocar72's Avatar
Rep:630
yes it's from 3gcustomz.com however they do not have a brakcet made for the rams yet, this is where i mounted mine with a brakcet i made and it was $90 shipped to the door, had one little dent next to where the valve screws in.
14.268 @ 95 MPH Full Trim
catch can for 07 5.7 brusk Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 32 08-22-2014 01:20 PM
HELP!!! Got my BT catch can and don't know how to install it... js1977 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 01-06-2012 11:32 AM
Catch Can - Worth it? Ram15002ndgen Dodge Ram General Discussion 13 01-29-2011 06:22 PM
BEWARE whom ever has catch can cold weather mineralram 5.7L (345 cu in) HEMI V8 Specific Topics 17 01-01-2011 08:01 PM
Catch can install? Gron86 2009 Dodge Ram Forum 27 12-07-2010 12:22 PM
