2002 magnum 5.9 rough idle/ stallout when cold. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 10-11-2011, 04:47 PM
ahhmann77 ahhmann77 is offline
Vehicle: 2002 Dodge Ram 1500 5.9 L 4x4
ahhmann77 is on a distinguished road
Default 2002 magnum 5.9 rough idle/ stallout when cold.
I have 2002 Ram 1500 4x4 with the 5.9 litre gas engine. I just got it a month ago. It is having a bad idle after it runs for 20 to 30 seconds at idle. Then the idle will want to drop dow to under 500 rpm and it acts like it is chugging or will choke itself too much gas. Smells like it is rich. It will almost run like this for a couple of minutes and then it iwll pick itself up to normal idle and smooth out. It will do this on almost everytime it is ran and restarted. Even after a little 5 minute cool down. I know these are known for intake leaks, but it sure seems like it would be something else. It has no check engine light on. It has stalled out a couple of times. I took it back to the Dodge dealer and they say it is due to the aftermarket exhaust, which I know is BS. CAN anyone give me a clear direction on what to change out. I am a Nissan Technician for Twleve years, so I have no problem doing the work. Anyone please help.
Old 10-11-2011, 07:20 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
maybe the throttle position sensor when they go up it idles like crap. there like 20 bucks . might be worth a shot. good luck
-PAT-
Old 10-11-2011, 08:42 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
It seems like it should be something else? OK, and it could be, BUT you must eliminate the manifold first. The vacuum leak throws the electronics into a tizzy. Sucks oil, which can cause rattling and misfire. The leak causes a run lean condition, which the computer tries to correct for. Misfire and fatter fuel delivery..... Anyone smell gas? Could be the TPS as mentioned, or any one of several other sensors. It's what I hate about these computerized models.
Rough Idle, Bad mileage, EGR valve? madmax0r 5.9L V8 Specific Topics 11 01-29-2012 10:08 PM
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
need help, very rough cold start idle Apathy13 5.9L V8 Specific Topics 4 01-04-2011 12:31 AM
Stalling in cold weather. Air Idle Valve? Todd F 5.9L V8 Specific Topics 3 12-06-2010 10:12 PM
Rough Idle when first started 2002Sport 5.9L V8 Specific Topics 16 07-21-2010 02:01 PM
