Old 10-12-2011, 09:56 AM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
Question Radiator stop-leak - good or bad?
I had posted earlier about my leaking radiator. I'm going to try to get a pair of vise-grips down in there and crimp the clamping strip just a smidge tighter, but failing that the last step before installing a new radiator would be to use some stop-leak.
I've heard good and bad about the stuff. Anyone got any input, pro or con?
Thanks!
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Old 10-12-2011, 10:02 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
IMO, 'Stop Leak' should be avoided unless all other avenues of repair have failed.....or your in the middle of nowhere and need a solution to get to a repair facility.
I have used the product many times in the past, and it has always lead to problems down the road, which became very costly to remedy. I now will do whatever is necessary to 'fix' the problem properly, and this has proven (to me at least) to be the most cost effective long term solution.
brad
Interested in one of my mods?
Old 10-12-2011, 10:10 AM
DaSOB's Avatar
Rep:51
Thumbs up
That's pretty much the way I had always thought. I used to do mechanic work years ago and back then I told folks to avoid using stop-leak. I just thought that maybe there was some "new and improved" stuff out there, but I guess it's all basically the same.
I'm going to try crimping down the clamp strip - I've been successful with that in the past. Failing that, I'll just have to drop in a new radiator.
Thanks!
Ah Luv Muh Truck!!
Old 10-12-2011, 10:12 AM
Rep:4072
Used it several times myself on my old Ram and have to agree, it will get you by in a pinch but I wouldn't suggest waiting too long after that to have it repaired/replaced properly as with most things like that, it's just a "quick fix" enough to get you out of a bind.
Old 10-12-2011, 10:25 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
What they dont tell you about things like stop leak, is that while they do work (for a time) They are HELL on components. Might not hurt your radiator anymore, but prolonged usage will cost you a waterpump or thermostat as well.
I would throw an egg in there before stop leak, and then take it straight to the shop, or order my new radiator online.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 10-12-2011, 11:12 AM
pupdawg pupdawg is offline
Vehicle: 2012 Dodge Ram
Rep:45
pupdawg is on a distinguished road
VERY BAD STUFF, avoid if at all possible!!!
Old 10-12-2011, 11:13 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Crap. Do the repair correctly.
Old 10-12-2011, 11:29 AM
Rep:45
Your avatar is just plain wrong! LMAO!!!
Old 10-12-2011, 12:16 PM
MFitzs70's Avatar
MFitzs70 MFitzs70 is offline
Vehicle: 2007 Ram 1500 5.7 Hemi BigHorn
Trim Level: ? Big Horn ?
Color: Reddish
MFitzs70 is on a distinguished road
Yeah stay away from the stop leak products...only use if your standed out in nowhere land..then flush and fix it right when you get back. I've repaired them by soldering but also have had luck with 5min epoxy...just make sure it is clean before applying.
Old 10-12-2011, 01:03 PM
THK THK is offline
Vehicle: 02 Dodge Ram
THK is on a distinguished road
Do not use stop leak or other type products. Buck up and get it repaired properly.
Radiator Leak iceman5679 V10 Specific Topics 8 03-19-2011 12:28 PM
Strange Oil Leak - Opinions Welcome rehartline 5.7L V8 Specific Topics 5 02-20-2011 05:51 AM
My trucks flashing a P0420 and a P0442 code jcasey10 5.9L V8 Specific Topics 10 09-15-2010 02:10 PM
bad news, good news toddrod Jokes/Humor 8 08-12-2010 09:23 PM
really good tire 984wdram Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 06-03-2010 05:59 PM
