Radiator stop-leak - good or bad? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 10-12-2011, 07:50 PM
hockeyguynick hockeyguynick is offline
Vehicle: 2006 1500 Laramie
Color: Blue/Silver
hockeyguynick is on a distinguished road
Back when I was a mechanic every head gasket job I had, there was stop leak all over in there. It gums the engine up so bad, and is a pain to clean out. T-stat, water pump, water jacket, all coated in the stuff. I hate stop leak with a passion now, lol.
Old 10-12-2011, 08:10 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I have used an old rat rod trick... right from the kitchen.... plain ground black pepper. It will get into the source of the leak then it will swell up and stop the leak, since it is soft and biodegradeable, it will eventually break down and start leaking again but it will give you time to save up for a new radiator. Just add as needed, but only as a last resort. Flush the system before installing the new radiator.
I Am Groot !
Old 10-12-2011, 08:19 PM
moparornocar72's Avatar
Rep:630
Put a new radiator in and be done with it.
14.268 @ 95 MPH Full Trim
Old 10-13-2011, 12:01 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
ditto, stay away, it also gums up the heater core, think the radiator and waterpumps bad to replace, try replacing a heater core, PITA
Old 11-02-2011, 03:04 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
Raw egg in the radiator will seal it up for a few months.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 11-02-2011, 03:07 PM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
Thanks, all. I went ahead and put a new radiator on it. $150 from Autozone, good for another 3-4 years.
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Old 11-02-2011, 03:39 PM
Rep:630
And a lifetime warranty!
Old 11-02-2011, 04:17 PM
Rep:2929
egg keep was good for temporarily sealing cast iron engine blocks, like a '32 ferd
In my toolbox i keep a couple small containers of ALUMASEAL, it doesn't harden without hitting air, great for driving a vehicle when you don't have the money for a repair or replacement, make sure your fill hole, where the radiator cap goes, is cleaned off, leave no aluminum flakes on there
Red Pepper like what is used on pizza actually works better the the coarse black pepper to stop or slow a radiator leak
a better fix:
If it turns out that the radiator itself is the source of the radiator leak, it may be possible to patch it - at least temporarily - with a ""cold weld"" epoxy such as J-B Weld. The problem with commercial radiator ""sealants"" is that they impede the flow of water in the radiator core and abrade the water pump seals - but never actually seal the radiator leak. Once you have identified the source of the radiator leak - usually on a seam - drain the radiator, clean the area around the leak thoroughly, then apply the J-B Weld. Before refilling the radiator, move the overflow line over to a vacuum port on the intake manifold, then remove the distributor cap and crank the engine a few times. The vacuum will pull the JB-Weld into the cracked seam, making a better seal to prevent the radiator leak.
If you determine that the radiator leak culprit is a broken radiator tube, you'll need to dig the cooling fins away from the tubing with pliers. Next, cut the tubing and wrap the cut ends up on themselves (like a tube of toothpaste). Crimp each end tightly, then apply JB-Weld.
Once repairs are affected, it will take about two hours for the JB-Weld to fully cure. It's also desirable to use a lower pressure cap (about 7-9 lbs psi). Remember that this is a temporary radiator leak fix.
Old 11-02-2011, 05:28 PM
budro1 budro1 is offline
Vehicle: 2003 1500 Regular Cab
Trim Level: Plain Jane
Color: Blue
budro1 is on a distinguished road
I have used stop leak when i was in a bind, but i didn't repair or replace the radiator and ended up with some costly repairs. I will use it again if I'm in a bind, but I will be sure to make permanent repairs ASAP.
Old 11-03-2011, 05:00 AM
nlneilson nlneilson is offline
Vehicle: 1995 Dodge Ram 3500 Diesel
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
nlneilson is on a distinguished road
ALUMASEAL,
J-B Weld.
In the last 40 years have tried several, ALUMASEAL seems to work the best and only in the recommended amount.
I have a Porsche 928 (I just bought the Dodge Diesel Dually).
A stick punctured the lowest two cross tubes.
A new radiator cannot be ordered through AutoZone, etc.
They a VERY expensive from a Porsche dealer!
Took it off, cleaned the area and cleared the area of fins.
Used a big bunch of J-B Weld and let sit for a day.
That area never leaked a drop after that.
Got a used radiator off ebay but did not replace it until a few years later.
Radiator Leak iceman5679 V10 Specific Topics 8 03-19-2011 12:28 PM
Strange Oil Leak - Opinions Welcome rehartline 5.7L V8 Specific Topics 5 02-20-2011 06:51 AM
My trucks flashing a P0420 and a P0442 code jcasey10 5.9L V8 Specific Topics 10 09-15-2010 02:10 PM
bad news, good news toddrod Jokes/Humor 8 08-12-2010 09:23 PM
really good tire 984wdram Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 06-03-2010 05:59 PM
