Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-12-2011, 10:34 PM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
Default LONG HAUL- front driveshaft?
This weekend, im heading out to michigan on friday, then turning around and coming back sunday. Its almost a 400 mile journey of 90% interstate driving (65 mph), so my question is.... Should I pull the front driveshaft out? I hae already replaced the cv joint once, and at $212 to have the old shaft rebuilt, i really dont want to do that again. I plan on taking the shaft with me just in case, but i have heard that running fast speeds for long periods of time does one helluva number on that joint. TIA
Old 10-12-2011, 10:47 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Strange....driven my truck from Phoenix to Iowa, Phoenix to Tulsa and Tulsa to Minneapolis twice and never dropped the front shaft. It's about the only original piece on the truck (which means its gonna fail soon).
It shouldn't be spinning while your truck is moving unless your CAD is stuck in the actuated position so both tires are locked. Usually your 4wd light should stay on. Have someone observe your truck while it is driven and see if the front shaft turns.
Old 10-12-2011, 11:34 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
If your blowing u joints out with the front shaft free spinning there is something misaligned in your front end. You may see 1-1.5 mile a gallon increase but It's not worth it to me
Old 10-12-2011, 11:39 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I agree, your axle disconnect will release your front driveshaft from its responsibilities, while in 2wd, it may lope along, viscosity drag, but it certainly wont be turning at 75-80 MPH, maybe 5 or 10 MPH., unless you have 4wd selected. your shifter will directly disconnect your trans case, and the lack of vaccum will leave your axle disconnect freewheeling. My 98 has a slight lag when connecting, thats the delay in your '4wd' light coming on, as far as I know(vaccum doing the connect thing)
Old 10-13-2011, 01:07 AM
Color: Mineral Gray
Rep:177
I wasn't even thinking about older 1500s having vacuum connect/disconnect. I was just thinking their solid axles were like the ones on 3rd gen HDs an there front axle was always connected and the shaft always spins
Old 10-13-2011, 05:48 PM
Rep:26
The joint was blown when i bought the truck. This is the first serious long haul i've taken the truck on, and at 400 miles one way, its definately going to be a test.
Front end noise bkirchner 4.7L PowerTech V8 Specific Topics 4 11-22-2016 12:58 AM
front license plate? Freightrain Body & Interior 15 03-21-2011 06:52 AM
2000 ram sport -- front end issues!? jaredtowne 5.9L V8 Specific Topics 7 12-05-2010 09:03 PM
In for the long haul delta Newbie Checkin! 11 12-03-2010 08:50 PM
Question about adding Bilstein 5100s (front is sitting lower again) City Slicker Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 17 04-20-2010 10:53 PM
