Dodge 1500 one ton axle swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-13-2011, 04:16 AM
sethprofitt sethprofitt is offline
Vehicle: 1998 Dodge Ram 1500
sethprofitt is on a distinguished road
Default Dodge 1500 one ton axle swap
I have a 98 dodge ram 1500, 360. I've been considering swaping them out for a dana 60/80. A couple questions i have is telling the difference in the 60 and 80. Im not to familiar with dodge onetons. I know in a chevy 60 the easiest way to tell is it has 3 u-bolts and studs on the pig. But on the 80 i have no idea. Just want to make sure i dont show up some where and buy a dana 70 under the impression i'm getting an 80. I'd appreciate any help i can get and any opinions about 1 ton-ing my truck thanks
Old 10-13-2011, 04:49 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well easiest way is to just look at the casting number on the housing. 60's say 60, 80's are stamped 80
60's axle tubes are 3.125" ,70s 3.5" and 80's are 4"
What are your plans for stepping up to one ton axles?
Old 10-13-2011, 05:13 AM
I do tug a truck, and i've learned my lesson on the halfton axles.. 2 axle shafts and a ring and pinion later lol
Old 10-13-2011, 09:27 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Time to step up to a diesel? Beefing up 1 component may stress other components to the point of breaking....
Old 10-13-2011, 11:12 AM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I dont have anything constructive to add to this thread but I had to say, jesus SeattlePete.. you're avatar is disgusting. But strangely I can't stop laughing at it.
Old 10-13-2011, 11:35 AM
Rep:24
Yeah, it IS kinda nasty, isn't it? hehehehehehe
Old 10-13-2011, 02:11 PM
That's what i was hoping to eliminate was the chance of breaking. With the axle swap theres not much of a chance of anything breaking but maybe a u-joint here and there.
Old 10-13-2011, 02:36 PM
Rep:24
U-joint, trans, transfer case- all the bits that may get stressed. How much weight are you towing?
Old 10-13-2011, 05:09 PM
Im not using it as a major tow rig.. maybe occasionally hauling a buddys truck or a quad, im just mainly planning on doing tug a truck with it. With 1 tons it'd be in the 6500 lbs class, so i'd be pulling another 6500lb truck
Old 10-13-2011, 09:20 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I'd find a donor rig and have at it. If it's not a diesel although I believe most 1-tons are, you could get the HD transfer case off an auto and it should bolt on. This way you'll get the driveshafts too.
I believe the 2002 1 tons which are still 2nd gen trucks, had front axles with no CAD. One less thing to go wrong!
lifted dodge ram 1500 price? opnions?? usmcoorah LD RAM - General Discussion 4 10-08-2011 10:04 AM
2010 dodge ram 1500 trx single exhaust swap for a dual exhaust topbanana3767 2010 Dodge Ram Forum 19 08-27-2011 06:50 PM
Programmer for 2011!!! philpott50 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 11 08-16-2011 12:06 AM
2011 Dodge Ram 1500 Laramie 4X4 kuffs565 Newbie Checkin! 9 08-15-2011 04:10 PM
Front Axle swap and other info Crazy Canadian Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-12-2009 06:05 AM
