2 cans of break fluid today - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 10-13-2011, 05:28 PM
Pepper420's Avatar
Pepper420 Pepper420 is offline
Vehicle: 1998 Dodge Ram
Trim Level: Larime SLT
Pepper420 is on a distinguished road
Default 2 cans of break fluid today
O.K. I have put 2 cans of break fluid in my ram today. I can not locate any leaking around the tires, nor the master. What else could it be? Where is it going?
Old 10-13-2011, 05:43 PM
Rep:2954
If your master cylinder is dry on the bottom & the wheel cylinders are dry on the backing plates
There must be a fitting leaking, somewhere along the frame
UNLESS the fluid is leaking some how into the brake booster
If your vehicle took 2 cans of fluid, you now have air in the lines & no reliable brakes
You need to fix the leak & bleed the brake system
Good Luck
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Not too many places it can go:
  • leaking at the wheels
  • external leak at the master cylinder
  • internal leak at the master cylinder
I'd look at #3....
Old 10-13-2011, 06:52 PM
Pepper420's Avatar
No leaking at the wheels or along the frame that i could find.
How do I check the break booster to see if there is fluid in it?
Internal leak in the master cylinder?
Old 10-13-2011, 07:00 PM
Rep:24
Take off the master cylinder; check the piston for leaks.
Old 10-14-2011, 12:56 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Park it somewhere dry and pump the brakes, then look under for drips.... Take two bolts off the master cylinder and see if there is fluid it should be dry ( there shouldnt be any fluid unless the seal is leaking there then it will be wet. )
I Am Groot !
Old 10-14-2011, 01:28 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
If the master cylinder is leaking internally, that is it is leaking past the plunger seal back into the bore, it will not lose fluid but the brakes will feel like crap and the pedal will gradually depress. If you are losing fluid you have some sort of external leak.
New Recall k36 found it today at Dodge dealer - REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR - Pic RAMTX 2011 Dodge Ram Forum 131 09-23-2011 10:36 PM
Where did it go????????? bigred0603 4.7L PowerTech V8 Specific Topics 5 04-03-2011 11:54 PM
BAH!!! Was on ramforumz today and the enemy tried to break in!! brvheart Jokes/Humor 9 07-19-2010 09:54 AM
Very Odd Transmission Fluid Issue mck89 4.7L PowerTech V8 Specific Topics 4 06-08-2010 11:36 PM
Chrysler Policy On Fluid Flushing RamTech Dodge Ram Knowledge Base 11 04-28-2010 08:24 AM
