Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Old 10-03-2011, 10:11 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Exclamation help need to replace brake line
Hi, My brake line from the front to the rear axle needs replaced. I would like to know what the metal blocks are that are located on top of the rear axle + the one behind the front wheel well liner. Are these 'blocks' just a metal block OR are they mechanical in relationship to the ABS? I would like to eliminate the front block and run new tubing from the ABS unit to the rear axle. IS this doable? OR can someone shed light on what these blocks are? thanks!
Old 10-04-2011, 12:56 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
If it were me I wouldn't change the setup, I'd just replace the line. The metal blocks are usually fluid distribution blocks that equalize the brake pressure between 2 or more calibers/drums. If you eliminate them, more than likely your truck will throw a code and you may have issues with a wheel locking up. Your brakes are a safety issue, I wouldn't go doing any custom mods on them unless there are kits specifically designed to do so. Just my 2 cents. Good Luck!
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 10-04-2011, 08:01 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
^^What he said^^
Old 10-04-2011, 08:36 AM
Rep:1385
I agree ^. The front block is likely a proportioning block to send different pressures to each wheel, and the rear block is usually just a T, no real issue replacing or removing this but you do need it to split one line into two for each rear wheel...
Old 10-04-2011, 10:08 AM
Trim Level: LT
Color: almond
Rep:19
Default brake line update
UPDATE on REAR block on top of axle. I think I know what I'm looking at, but maybe others can chime in. The block on top of the rear axle that receives the brake line from the front not only is for the brake system; ie splitting the feed to both L/R rear brakes, but ALSO the 4th line coming out of it, a rubber tube to the top of the L wheel is the AXLE BREATHER built into 1 block? I'm sure that is what I'm seeing. Fortunately, I don't have to mess with them. With PB blaster + vice grips, I was able to remove the terribly corroded fittings. After brushing off all of the rust, I believe they were once 9mm; but they rounded off and had to use the vice grips. Thanks to the creator of that tool! d)
Old 10-04-2011, 05:04 PM
Trim Level: LT
Color: almond
Rep:19
While at the stealer today to pick up 2 front speed sensors, I asked a mechanic about the block on top of the rear axle. It is in fact a breather for the axle that RUNS THROUGH the block for the rear brake -- 1 in/2 out + the breather for the axle passes through this brake fluid distribution block. WHY??? Your guess is as good as any!!!
Ruptured Brake Line lwalper Dodge Ram General Discussion 8 06-01-2013 10:12 AM
Brake Line Flaring How To RamTech Dodge Ram Knowledge Base 6 04-28-2013 11:13 PM
Brake line BLOW OUT! bamasport Brakes 2 10-03-2011 10:21 PM
Dodge Ram Van Conversion Window Replacement... ramvan2500 Dodge Ram Vans 4 05-24-2011 11:32 PM
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
