Old 10-13-2011, 06:54 PM
85buggy's Avatar
85buggy 85buggy is offline
Vehicle: 2011 Dodge Ram 2500
Color: Omaha Orange
85buggy is on a distinguished road
Smile Cold & Snow & ice it's coming !
I have never had a Dodge truck I switched over after to many ford problems. My ford was good in the snow I have been in some mud and I thought the truck handled it better then the ford & I didn't have to go to 4wd to get out. What should I expect this winter do i have to weigh down the back with sand ? Also my ford diesels had engine heater plugins this new truck says they aren't needed less then -20 deg .What should I expect for a normal warm up for decent heat ? Lastly shifting into 4x4 my ford always clunked it was was a 2011 not a oldie will this truck shift more quietly rolling along say 45 mph ? I really like this diesel compared to my ford 6.0 diesel.
Old 10-13-2011, 08:15 PM
Rep:2705
Being as you live in the north, you MAY have an engine heater cord tucked away in the upper part of your fender well(s)
A battery blanket can be useful
sand bags always come in handy for weight or traction in the winter, especially in a empty pickup bed
Personally i can't believe for a second what the manual reads about warm up time with any engine.
as for the transmission, rear end, brakes, & bearings, you have to drive slowly until they can warm up, that is not hard to do in 6 inches of snow
I will not be able to help you the shifting stuff
I was raised in New England, but vehicles didn't have all the fancy stuff back then
Old 10-13-2011, 09:06 PM
redlightrico's Avatar
redlightrico redlightrico is offline
Vehicle: 2015 Sport 4X2
Rep:15
redlightrico is on a distinguished road
waaaaaaay up here in the Great white north mine did excellent with no weight at all in the back, barely ever had to put it in 4wd. Up here Battery blankets come stock as well as the Block Heater cords even though I never plugged it in once. we hit a 2 week period back in January that hit -40 C every night and the truck was outside in open air. Warm up times ranged from 3 to 7 minutes to get heat (without a weatherfront)
The list is soon to be long....much to my wife's dismay
Old 10-13-2011, 09:16 PM
squig69 squig69 is offline
Vehicle: 15 quad cab
Trim Level: sxt
Color: granite metallic crystal
Rep:13
squig69 is on a distinguished road
i was wondering the same thing about adding sandbags in the back. if they're not needed then at least ill have sand there for the icey boat launches in the winter
things out of square make me cry
Old 10-13-2011, 09:41 PM
Hiker Guy Hiker Guy is offline
Vehicle: 2011 Dodge 1500
Hiker Guy is on a distinguished road
Originally Posted by redlightrico View Post
we hit a 2 week period back in January that hit -40 C every night ....
Colorado gets cold, but not THAT cold!
I like the ideas of a Battery Blanket & Block Heater though. Good ideas.
4wd and LSD should get me around most areas, particularly with sand bags.
Old 10-14-2011, 06:11 PM
85buggy's Avatar
Color: Omaha Orange
Thanks for the input the salesman said the block heater is a option thats not on this truck. Had I ordered it I would have gotten it. If I have it where should I look (block heater cord) ???
Old 10-27-2011, 02:13 PM
Northernmedic Northernmedic is offline
Vehicle: 2011 Ram 1500
Rep:26
Northernmedic is on a distinguished road
Take a look in the engine compartment, pass side by the rad and the fender.
My wife is the one that daily drives our ram. I told her that when it's iccy out just to put it in 4wd auto and forget about it.
Old 10-27-2011, 02:35 PM
Rep:2705
I read this online
It's behind and a little the the right of the passenger side head light. It's a black cord with plug cover over the grounded plug itself.
Old 10-27-2011, 04:10 PM
AlphaInfinity AlphaInfinity is offline
Vehicle: 2011 Dodge Ram 1500
Rep:30
AlphaInfinity is on a distinguished road
The auto trak systems in these trucks are pretty good. Just stick it in auto if there is any doubt and forget about it.
Tires and driving habbit are also very important. No reason to use the engine block heater on a gas powerplant until it gets really cold. I know the boys north of us in Alberta on the oil sands plugin their diesels all the time, but they have weather that justifies using them.
Old 10-27-2011, 04:36 PM
Rep:2705
Back in the 1950 & 60s, we used cardboard shipping boxes, like what refrigerators come in, to lay on the ground under the engine compartment & transmission in the winter. We never had a frozen engine or radiator, the ground holds the freezing cold & your engine compartment is right above it, the cold does Not come down through your hood, it comes from the ground
many people that need a block heater, usually put them on a timer, say you need to drive the vehicle at 6 am, you would set the timer to come on about 3 hours before that
Take Control of Your Engine Block Heater
Electric block heaters are commonly used in cold climates to heat a vehicle engine prior to driving. Heaters are connected to normal AC power and have a heating coil that goes into the engine block. In cold climates block heaters are often standard equipment in new vehicles.
Using a block heater not only helps the vehicle start more easily and reduces wear on the engine, it also helps air quality. This pre-warming sharply reduces the amount of pollutants created during the first few minutes of a “cold start.” Studies show that, whenever it is 20ºF or colder, using an engine block heater for two to three hours prior to starting the vehicle can cut carbon monoxide emissions by an average of 60%.
Also, with a warmed engine, fuel economy will improve as much as 10%, and the passenger compartment defroster and heater will work faster. School buses and other fleets often use block heaters to reduce engine warm-up time, avoid starting difficulties, and help defrost windows.
Timers Save Energy
It only takes 2-3 hours for a block heater to fully warm a vehicle engine. But for convenience, many people plug it in when they arrive home in the evening, leaving it on all night! To automate the on/off heating cycle, you can use a programmable timer to turn on the block heater at the appropriate time.
http://www.google.com/products/catal...d=0CHoQ8wIwAw#
Cold Weather Coming!! Mopar Online Parts Mopar Online Parts - Dodge Ram Accessories! 1 09-20-2011 10:22 AM
Diary of a Demented Snow Shoveler BigSwede Jokes/Humor 11 01-13-2011 01:14 PM
Snow My Word SNOW smarthead2006 Off Topic Discussion 20 02-07-2010 10:51 AM
Cold air coming in on passenger side???? kjtc6 Body & Interior 1 01-29-2010 11:53 PM
Snow snow snow !!! LYC79 Off Topic Discussion 11 01-02-2009 12:03 PM
