Old 10-14-2011, 01:08 AM
dauer53's Avatar
dauer53 dauer53 is offline
Vehicle: 2011 1500 Quad Cab Sport 4x4
dauer53 is on a distinguished road
Default 295/60/20
Curious if anyone has squeezed some these onto a 4th gen 4x4 with factory 20x9 and no spacers?
I don't want to beat a dead horse but I'm looking for a little taller and wider tire for a 2011 4x4 with bilsteins without having to get new rims or use a spacer...
Old 10-18-2011, 01:56 PM
ArkRAM11's Avatar
ArkRAM11 ArkRAM11 is offline
Vehicle: 2011 Ram 1500 Laramie
ArkRAM11 is on a distinguished road
If you have bilsteins and they are set on the top setting then the height won't be an issue. However I cannot confirm rather or not the width will. I too am looking at the same tires but plan on a negative offset wheel.
Old 10-18-2011, 07:53 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
I am currently looking at the same thing as well. I have the bilsteins set on the highest setting, however I found an aftermarket set of wheels that I like with a +10 offset. I didn't want to go with a negative offset, because I didn't want to have to run fender flares. Hopefully someone will chime in with an answer on the offset needed for that tire size.
Old 10-18-2011, 08:49 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I know others have the 295/65r20 and have to run a 1/4" spacer with the stock +18mm 20x9 rims to avoid rubbing. They are the exact same width (12.13") but are 35.47" tall where the 295/60r20's are an inch shorter. Height wont be the issue since you're leveled, but I imagine that you'll have to run the 1/4" spacer too.
Old 10-19-2011, 06:39 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
I have 33/12.50R20 Toyo M/T on my factory 20s with no spacers (metric equivalent of 315/50). They have very large sidewall lugs as well. I have no rubbing up front and on the rear it will only touch the inner fender liner if the oposite wheel is at max extension (fully drooped) even then just enough to disturb the dust, nothing more. Admitedly the front is close to the upper a-arm, but it does not make contact at any point.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 10-20-2011, 11:08 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
http://www.ramforumz.com/showthread....600#post554600
This is a pretty good example for you. It says -20 offset to get the 295/60/20 to fit without rubbing, and it looks borderline if you would need flares or not, that would probably depend on how many gravel roads you run.
Another option is the 285/65/20 BFG's. I have them on stock rims and they look really good. I wouldn't mind a bit wider, but they look good, don't rub, ride well, and don't need fender flares.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 10-21-2011, 12:44 PM
Rayne's Avatar
Rep:73
^ Those are also the Terra Grapplers which in a 295/60r20 are wider than the Trail Grapplers. The Terra's being 12.36" and the Trails being 12.13. Not much of a difference but I honestly don't think you need to go as far out as a -20 offset to not get the Trail's to rub. I have the BFG 285/65r20's on the stock wheels (+18mm) and no spacer, and they dont rub at all. The BFG's are I think around 11.8" wide.
Old 11-09-2011, 01:25 PM
RockiesRam RockiesRam is offline
Vehicle: 2009 Dodge Ram
Color: Brilliant Black Pearl
RockiesRam is on a distinguished road
I have this size with stock suspension, only thing I have are 20x9 0 offset wheels and 1/4" spacers, no rub or anything
295/60/20 Nittos on 07 RAM VanillaHemi07 Dodge Ram Wheels And Tires 36 04-08-2012 03:44 PM
Nitto Terra Grappler - 295/60/20 - Pictures ABD26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 09-07-2011 12:34 AM
nitto 295/55/20 vs 295/60/20 seabass Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-03-2011 02:22 PM
295/60/20 Terra Grapplers??? JF2004 2010 Dodge Ram Forum 46 07-08-2011 11:11 AM
295/60/20 kingquad06 Dodge Ram Wheels And Tires 2 05-06-2011 03:09 PM
