Old 10-14-2011, 11:06 AM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
Default Front Passenger Seat Rattling
Well, I just passed the warranty kilometers a month or so ago, so I guess I had to expect SOME kind of trouble:
My front passenger seat rattles a bit when I go over small bumps in the road. Does anyone have this? If so is there any resolution?
It seems to have just started recently, and it has taken me a while to figure out WHAT is making the noise. I finally realized that if I grab the passenger seat and pull or hold on firmly as I drive it does not make the noise. That was the tip off.
Im wondering if there is something that can be tightened or adjusted?
Ambitious, but rubbish!
Old 10-15-2011, 08:34 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
the exact same thing happen to my 2009 sport, and as same as you when i was pulling on it, it stop
i drove it to the dealership, they said they put grease on the sliding rails under the seat, it needed to be grease
never had problems with the seat since then
so thats what i would do if i was you
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 10-15-2011, 08:38 AM
crusher's Avatar
Rep:363
also make sure that you put enough grease so that where the seat and the rails make contact when you hit the holes it wont rattles anymore
Old 10-15-2011, 09:04 AM
gregster's Avatar
Rep:81
Great advice, Crusher, thanks! Rep points for helping me solve this annoying noise!
I wasn't thinking about grease... it seemed like something needed to be tightened.
I guess I will go see what kinds of grease Canadian Tire has for this type of application and get rid of the annoying rattle noise!
I'll let you know how it goes.
Old 10-25-2011, 10:02 PM
crusher's Avatar
Rep:363
so did you try it with the grease?
Old 10-27-2011, 10:47 AM
Brentshemi Brentshemi is offline
Vehicle: 2010 Ram Sport Crew
Rep:19
Brentshemi is on a distinguished road
I thought mine was doing the same thing, but it was just the way the seat belt buckle was sitting against the plastic pillar.
Try fastening the seat belt and see if it happens.
Old 11-23-2011, 07:27 PM
crusher's Avatar
Rep:363
hi gregster,
so did you try to fix your seat problem with the grease in the sliding rails??
its been two years about since mine was done and still no problem's with it
Old 11-24-2011, 12:30 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I thought my seat was rattling it turned out to be the seat belt vibrating up against the door.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 11-24-2011, 12:38 AM
Don't forget to check the seat rails and the connections to make sure they are securely fastened.
And, check for any loose harnesses or cables underneath. Zip ties can be your friend if a clip has broken.
Old 11-24-2011, 01:48 AM
Rep:2616
In the 2009s, they all had a passenger seat rattle, there was RRT out on it
maybe find out what they did on the RRT
Passenger Seat Nosie smarthead2006 Body & Interior 18 03-18-2012 12:17 PM
Enabling Front Seat Video Without Lock Pick RamTech Custom Dodge Ram Interior Modifications - Custom Audio / Video 16 01-31-2012 04:57 PM
98 Dodge Ram pickup and both the front seat belts are stuck so that you can't pull them out koalatyman Body & Interior 2 05-08-2011 12:55 AM
Subwoofers under the front seat? Ryank Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 08-30-2010 04:10 PM
Front Seat Questions mojii Dodge Ram Knowledge Base 1 03-15-2010 11:07 PM
