Old 10-14-2011, 10:44 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Default Bridgestone Blizzak DM-V1
How accurate are their tires within spec of the advertised tire ratio? I am looking to get two rear tires for that little help in traction on the cold/iced roads here.
My prefer tire and size were Blizzak LM-25 in 305/45/18 or 275/55/18 but could not find any but i am open to other suggestions. Looking for around 285 to 305 width with 29-30" height.
Thanks.
Old 10-14-2011, 08:29 PM
345cube 345cube is offline
Vehicle: 2008 Ram 1500 Hemi QC 4wd
345cube is on a distinguished road
Winter tires in just the back is a bad idea. It will help you go but won't help you stop. You will also get massive understeer.
For a cheap route, there are no other cheaper winter tires than Winterforce by Firestone.
2008 Ram 1500 QC 4wd
Bilstein 5100's - all 4 corners/eBay drilled-slotted ceramic brakes
Old 10-14-2011, 08:58 PM
Color: Satin Orange
Rep:627
AZ cold is not really cold, cold. If this helps i ran rear DR's and front Toyo Proxes straight through winter last year just fine. Just want to save the tread wear until next Spring.
Looking at this as a "poor man" DR vs what they really are intended for.
Best size for the DM-V1 for me would be 255/55/18. Pretty narrow but the 4/6 should help conceal it.
Bridgestone Dueler A/T Revo2 gregster Dodge Ram Wheels And Tires 11 12-12-2011 12:11 PM
opinions bridgestone dueler revo 2 snrusnak Dodge Ram Wheels And Tires 1 05-11-2011 11:50 PM
Blizzak DM-V1 dubstar Dodge Ram Wheels And Tires 2 11-27-2010 10:00 AM
