Purchasing 2010/2011 Dodge Ram....suggestions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-14-2011, 12:43 PM
nmhs
Default Purchasing 2010/2011 Dodge Ram....suggestions
Hello Everyone,
First time poster here and possible first time Dodge Owner. I'm in the market for a 1/2 or 3/4 pickup and it seems there are alot of options with Dodge and I'll be honest I don't know a lot about them. I've owned Ford and Chevy and Ford is to high priced and I'm not much of a Chevy Fan. I have some friends that own a Dodge and they like them. I'm after a 1/2 to 3/4 crew cab 4x4 truck with a gas motor. I haul small loads from time to time and maybe a tow behind camper once in awhile. Whats your recommendation? How is the fuel economy with a Hemi in a 4 door?
Thanks
Old 10-14-2011, 10:56 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Originally Posted by nmhs View Post
Hello Everyone,
Thanks
I can relate to some of your questions, I have the 1/2 ton crew cab with the hemi. Backseat room is excellent. I'm in the same boat, light loads for the most part, pull a travel trailer periodically. If you do decide to buy, buy one equipped with the heavy tow package, that would include a heavy duty cooling rad for both engine and transmission and buy one with the 3:92 limited slip rear diff. These are optimal pulling gears which will still offer decent gas mileage. The ride quality in general is upper shelf IMHO. I have the setup described and can achieve 20 to 22mpg often, just did it again today at 65 mph average, 13 mpg pulling my trailer weighing in about 5400lbs. That's US gallons. That's with 20 inch tires and rims. I have the SLT model, you can certainly go with a higher end truck and there are plenty of options to add, although the drivetrain isn't any different, the price will certainly increase. Good luck with your decision!
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 10-16-2011, 09:01 PM
fier23's Avatar
fier23 fier23 is offline
Vehicle: 2011 Ram 1500 Laramie CC
Color: Deep Water Blue Pearl
Rep:15
fier23 is on a distinguished road
I often haul about 4000lbs loaded with a Rzr 2quads 4 people and gear so maybe even more. I have a 2011 Laramie crew cab Hemi. I have the 3.55 gears and towing I can achieve an average of 15-16mpg. Unloaded i usually average 20-22 also. I would definitely go for the Laramie or long horn.
Jeremy
Old 10-18-2011, 08:16 AM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
Definitely find a truck with the 3.92 limited slip rear end. The 3.55 is not limited slip & you will be disappointed to have all that power & not be able to take advantage. Otherwise a great truck.
Old 10-18-2011, 11:51 AM
wickedpissahtruck's Avatar
wickedpissahtruck wickedpissahtruck is offline
Vehicle: 2014 Ram Laramie 4x4
Color: Maximum Steel Metallic 2 tone
Rep:23
wickedpissahtruck is on a distinguished road
I agree with the above comments, definitely go with the 3.92 gears, tow package, and a Crew Cab over the Quad Cab I would recommend as well. You will value the extra room in the back seat area. 20-22 mpg is definitely not the norm though. You should realistically expect 16-18 mixed driving if equipped with Hemi, 3.92 gears, 4wd. Good luck and you won't be disappointed!
Old 10-18-2011, 04:40 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
nmhs; 1500 to 2500 is a huge difference. From the sounds of it you should be fine with a 1500 and the 3.92 gears. Plus you'll save money and some fuel. Mileage for our 1500 has been average of 13.7. And that is hand calculated over the course of many months, and very average since we do about 50% city 50% highway with that PU.
Towing a 3500# trailer we get about 11 mpg (not that big of a drop and I commend the Hemi in that area). I also owned Fords (and a Titan) before my first RAM 3 years ago. No comparison as far as what you get for the money with the Titan being the exception.
Love our interior and all the room. Rides like a dream compared to leaf-spring pickups.
2016 3500 Laramie MC 385/900 with Aisin tranny & 4.10 gears: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 10-19-2011, 01:48 PM
Jim Ram's Avatar
Jim Ram Jim Ram is offline
Vehicle: 2010 Ram 1500
Jim Ram is on a distinguished road
I'd say you are better off with a Quad cab. The back seat is not that small and there is a bigger bed then a crew cab, plus they are less expensive (I'd still pay more for the quad cab, it's a truck and I'd rather a medium sized bed instead of a small one). Expect the gas mileage on a HEMI to be about 13mpg.
2010 Ram 1500 Navigation
2007 Accord EX V6 Navigation
Old 10-19-2011, 09:39 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
If you are going to pull a camper over 5,000 lb get the 2500. You can get the Crewcab 2500 with the normal 6.5 bed instead of the 5.5.
The 9.25 Rear Axle (1500) has a tendency to run hot when worked hard at heavier weights. Its also easy to get over on the rear axle and gross weights when hauling a heavier trailer.
A 2500 comes with the 10.5 and the available 4.10 gears and will have less issue with all of these. Better brakes and is a much better towing platform for a trailer over 5,000 lb.
The draw back to the 2500 is the solid axles (if you need 4WD) and leaf springs in the rear. Of course these turn into a plus when loaded or pulling.
Gene
Old 10-20-2011, 03:25 PM
rsg1963's Avatar
Rep:48
^^^^I basically agree with all of this except: I would bump the cross-over weight to about 6500#, add that a good Mag-Tec diff cover would eliminate heat issues for the 9.25 rear, and make it clear the ride quality is truly a night and day difference.
Massive Dodge Mud Rig, Need Suggestions. XSTork Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 09-15-2011 07:08 PM
Hey new guy with a hatred for dodge.... untill now...!! hereicome4u Newbie Checkin! 15 03-04-2011 06:53 AM
New to Dodge trucks acon1086 Newbie Checkin! 13 03-01-2010 04:42 PM
New 2010 Dodge Ram owner jdolotina Newbie Checkin! 11 02-06-2010 08:53 PM
Accessory mods/performance mods 4 a 94 dodge 5.2 (v8) any suggestions or opinions RedneckDodge Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 10-20-2009 07:45 PM
