Old 10-14-2011, 02:53 PM
keystone183 keystone183 is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Rep:58
keystone183 will become famous soon enough
Default Moving Rear View Mirror
Anyone attempted to move their rear view mirror a bit higher. It sits low enough to block a lot of view. I've put them back on before, with the stuff you buy from autozone or the like, but never pulled one off. Anyone have any experience with this at all? Advice?
Old 10-15-2011, 01:06 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I have removed mine before with a thin single edge razor blade, just take your time and just wiggle it under and around till the mount pops off.... all you need is some rubbing achohol/or acetone to clean the area, then use super glue to re attach it ( one or 2 small drops ) and a piece of masking tape to hold it in place till it dries, normally I wait a day to remount the mirror but it should be good to go after a couple hours. I always used super glue and never had one fall off, where I did have one fall off with the stuff from the auto store.
Mike
Old 10-15-2011, 11:36 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
My 09 has a double ball and socket mount. I was able to get mine high enough with that adjustment. I don't know if you get a good bond on the painted strip on the windshield.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 10-15-2011, 11:46 PM
The razor blade trick works. So does some adhesive remover.
Old 10-16-2011, 10:47 AM
RamJet06 RamJet06 is offline
Vehicle: 2012 Ram 1500 Quad Cab
Color: Deep Cherry Red
RamJet06 is on a distinguished road
YEah, I would just use a razor knife and take your time. It should pop-off. I'd be interested in some before-n-after pic's. I might like the idea myself.
Dave...
Ex-AF B-52 Crew Chief. Daughter is currently active duty, AF Security Specialist.
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 16 02-11-2015 06:32 PM
DYI OEM rear view camera tailgate connector vyruz Electrical 5 12-25-2013 03:21 PM
DIY An easy way to add Homelink ken99 Dodge Ram Knowledge Base 4 10-09-2011 12:06 AM
2009 Dodge Ram ST Crewcab 4.7 ?? sernul 2009 Dodge Ram Forum 16 02-19-2010 08:40 PM
Side View Mirror BigLoo Body & Interior 1 10-28-2009 05:29 PM
