Old 10-14-2011, 03:00 PM
countryb90 countryb90 is offline
Vehicle: 05 dodge ram
Rep:29
countryb90 is on a distinguished road
Default Ram side step bars
So i got this 05 4 door ram awhile back and the seller gave me the mopar side step bars that were on it. I decided to black them out and put them on. He only gave me one of the bolts and rectangular shaped nuts to attach them too the frame so i need 7 more. I tried my local dealer they said they couldn't order the hardware separately. I tried ace, lowes, auto stores, and called mopardodge they also said they couldn't sell the hardware separately. Any ideas seems kinda crazy that these little nuts are that hard to get and it sucks having the bars and no way to attach them. Thanks for the help.
Old 10-14-2011, 06:55 PM
RamJet06 RamJet06 is offline
Vehicle: 2012 Ram 1500 Quad Cab
Color: Deep Cherry Red
RamJet06 is on a distinguished road
How about getting some flat bar the width & thickness you need, cut the size rectangles you need and tap them yourself? Of course, it would be easier to tap the bar with multiple holes 1st, then cut to size. Shouldn't be too hard to make them.
Good Luck,
Dave...
Ex-AF B-52 Crew Chief. Daughter is currently active duty, AF Security Specialist.
Old 10-15-2011, 03:04 PM
Rep:29
Thanks for the reply i already made them got tired of waiting..thanks
Old 10-15-2011, 03:24 PM
The only other option I could think of is a hardware/fastener store.
Old 10-16-2011, 10:01 AM
Rep:29
I tried all the local hardware stores they didnt have anything the dodge dealer wouldnt sell me just the hardware said i had to buy the whole side step bars...what a joke. Its all good tho trip to lowes and a couple hours and i made the brackets and got them mounted up.
Old 10-16-2011, 10:16 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I think the Mopar bars use a heavy duty PEM Nut where they tie into the rocker panel. They have to be drilled out to be removed which is probably why you didn't get them or they are on the truck already (if the bars were ever installed on your truck). You might check and see if you already have them other wise I think you're probably best off going to the dealer for the install kit. I think it's less than $50.
A/C low pressure valve leaking sonocativo Heating & Cooling 56 06-05-2013 05:40 PM
Please help with side nerf step choice theweavman Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 07-24-2011 02:41 PM
Go Rhino step bars snrusnak 2010 Dodge Ram Forum 9 06-15-2011 03:42 PM
Best Step Bars united316 2011 Dodge Ram Forum 10 05-09-2011 11:26 PM
Need help choosing a set of Step Bars 03 Hemi Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 13 12-25-2009 06:58 PM
