Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 10-18-2011, 04:06 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
The puddle lights (on the bottom of the mirror) on my r/t only do 1 thing come on when you lock/unlock the truck they come off very simple as why i tinted mine to match my tails as far as the bulb did not care they are stupid and now are black.
Old 10-18-2011, 04:56 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
If you have an R/T,turn your left and/or right turn signal on and look at the clear lens..you'll see they are also turn signals with a yellowish coloration inside the clear lens. The turn signal bulbs are on the corners inside the clear plastic, while the puddle lights are on the very bottom. Both are inside the clear plastic lens, though.
Old 10-18-2011, 07:32 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
Ya lack of sleep meant they are turn signals/but like i said took them off and tinted them cause to me they are el stupidito lol
Old 07-03-2014, 03:00 PM
Budge Budge is offline
Vehicle: 2012 Ram 1500
Trim Level: Laramie 4X4
Budge is on a distinguished road
This can be done, but is not for the faint of heart. If you attempt this, you are doing so at your own risk!
- Start by operating the mirror to the fully down position.
- Grasp the top edge of the mirror, and pull it further then the adjuster did...this will release the top clips.
- Look down inside to see the lower hinge style clips...separate them and remove the mirror glass.
- Disconnect the heated mirror wires (if applicable)
- Locate and remove the 3 screws that hold on the mirror cover.
- Remove cover
- Locate latch tab for LED lighting unit and release
- Gently pry the LED unit from the housing.
- This might take some persistence, and the weather seal sometimes hangs on to the unit and resists it's removal.
Good Luck!
I just tried this on my '12 Laramie. It worked, but I wanted to add a couple of tips. After you pull down on the top of the mirror to release the top clips, use the electronic control to raise the mirror. This makes the bottom hinge clips slip right out. Also, there's no need to remove heated mirror wiring if you plan on putting the assembly back together again. Just FYI.
Can't a fella have a maroon truck in Texas and NOT BE AN AGGIE? C'mon!
Old 11-22-2014, 08:15 PM
VegasB VegasB is offline
Vehicle: 2014 Dodge Ram
Trim Level: Laramie Limited
VegasB is on a distinguished road
On the puddle lights, is there 1 or 2 little LED's that are supposed to come on? I have the one white/blue LED's but it looks like there is 2. Any help would be appreciated.
How to change disk brakes double0ram Dodge Ram Knowledge Base 16 05-25-2012 07:28 PM
upgrade side mirrors/ warning ramfan1500 2010 Dodge Ram Forum 27 05-07-2012 10:14 PM
Mirrors with Turn Signal cmatt4775 2010 Dodge Ram Forum 4 03-16-2011 05:25 PM
ST upgrade to turn signal mirrors? Chinchilla 2010 Dodge Ram Forum 7 12-28-2010 12:45 AM
How To: Front LED Turn Signal Install ICEMAN99TURBO Dodge Ram Knowledge Base 9 11-28-2010 02:24 PM
