ZDOG
Old 10-15-2011, 11:57 PM
Lothario80 Lothario80 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Color: Mineral Grey Metalic
Rep:41
Lothario80 is on a distinguished road
Thanks guys I needed a good laugh tonight.
Just figured out that the $300 I paid Visions Electronics (Yes I'm calling them out) to pre-wire and prep the truck was a complete waste of money. They ran speaker wire for the DVD unit power, and wired in defective RCA cables. Hooked everything up to the Lockpick and the video would flicker and go out. Tested a portable DVD unit with a different set of RCA cables and voila!
I just spent the last 2 hours completely removing all the garbage they installed and ran high quality wires. I'll be heading back tomorrow to get a full refund and drop the crap on the managers desk. If I had known that cutting a hole in the head liner and $20 worth of parts = $300 at Visions, i'd have attempted this myself in the first place.
Things I've learned:
The 12V constant feeding the rear dome light is well not constant. There is something in the Dome Light which must tell the truck to increase voltage. When I test the "constant" I get 3.4V fluctuating. When I hooked up the lights from the overhead they flash like a strobe (kinda cool actually). To make certain I didn't have a defective unit I used my probe with an LED and it was flashing as well. When I turn on the rear dome, the strobe effect is gone and lights working properly.
I am wondering if the factory dome itself when is turned on closes a circuit and flows the 12V from the switched to increase voltage? Anyways not too concerned it is a great conversation piece and as long as the lights turn on when the door is opened I am happy.
Door Switched is a Constant 12V when the door is open and is the middle pin in the connector.
Ground is the Black wire in the Connector (duh)
Rear Switched DC for the Ciggy Lighter is on the farthest left (closest to the centre console) harness under the driver seat. It is fed by a Purple/Pink Stripe and will go hot in Accessory Mode. Don't be confused folks the "Switched" power at the harness under the dash (thickest blue wire) will ONLY go hot when in "ON" mode not "Acc". If you tie any accessories in to this wire, they will only work in "ON" or when the engine is running.
PITA if you want to play Zelda or Super Mario Bros in the back seat with only the stereo and overhead running!
Lockpick CHR550 is working flawlessly and exactly as described. Only flaw i've found is on the RHB 430N, the pressing the power twice to activate the rear Camera doesn't work. Going to investigate this more.
If you have a Sunroof do NOT worry there are 2 fairly large steel support beams (approx 1 1/2" thick hollow)that run across the roof. Perfect location for a DVD unit mounting bracket. Hit those with your screws even 1" long and you're golden. The sunroof and slider both sit above these beams.
Headliner is held up with some crazy industrial velcro type stuff. A good tug releases the headliner no need to take it off. I was able to run all new wires over the side airbags, down the a-pillar and behind the glove box without removing any dash panels. Ran the power and ground down the B pillar on the driver side, under the carpet and back out the factory hole at the harness.
Its Miller Time!
K&N CAI - Magnaflow 18" - Putco In-Channel Vent Visors - Truxedo Lo-Pro Tonneau - 5" Carbon Fiber Antenna - Timbren SES - Smoked Tails & 3rd - Overhead 13" DVD - CHR550 Lockpick - DeBadged
Old 10-16-2011, 12:44 AM
Your time here is growing shorter by the post, facehugger.
The Mod Monster does not go away. You can slow it down, put it aside, ignore it...but eventually it comes back...with a vengeance...
The best way to deal with it is to do a little bit at a time, regularly, and save for the larger stuff. Have a plan...and give in...
Resistance is futile.
Old 10-16-2011, 01:59 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
Its Miller Time!
For the dome light you should use a relay and provide a 12v feed to the contacts, I found that trying to tap into the cargo light circuit by itself was not sufficient to power the lights under my Leer700. I suspect the dome circuit is the same, the TIPM is what drives the circuit.
For the lock pic, I also noticed that the double push to activate the front camera is timing sensitive, it takes some practice to get it right.
Congrats on getting it all working BTW.
sales@revelperformance.com
Old 10-17-2011, 12:43 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Just watch Dexter
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 10-17-2011, 01:25 PM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
Ill help with the ex wife if i get some mod money
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
Old 10-17-2011, 07:31 PM
LeroyJaxson's Avatar
LeroyJaxson LeroyJaxson is offline
Vehicle: 2011 Ram 1500
Trim Level: Express 4x2
Color: mineral grey
LeroyJaxson is on a distinguished road
I've been fighting the mod monster but it won't be long before it bites me.
Old 10-17-2011, 09:51 PM
RAMR's Avatar
RAMR RAMR is offline
RAMR is on a distinguished road
Originally Posted by js1977 View Post
LMAO!!! I got a buddy that always says "a friend helps you move, a good friend helps you move the body".... I'm just saying, if you got any GOOD friends, then you know your answer...
That quote is awesome
Old 10-17-2011, 10:02 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Did you use Dodge's PDF for the overhead install. I am only wondering if you use all the wires dodge want you to use.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 10-17-2011, 10:11 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Nail.......
I totally understand your concerns, they should have warned us about this before we signed the offer to purchase. Not that it would have made any difference
Head.......
Originally Posted by facehugger View Post
I feel with you !
But i found the REAL reason for this problem, believe me!
It's not the truck
it's not the ex-wife
it's not the loan we get
it's also not one of the single mod we do!
........It's only this forum makes us doing more modifications that we can't afford!
The proof is in the mods list in my sig. Unintended mods start at 'Tinted Tail Lights'.....
I really need to quit coming here.....well.....maybe once I hit 100 posts.
brad
Interested in one of my mods?
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
My truck got hit yesterday. GeauxHunting Dodge Ram General Discussion 41 11-19-2010 02:15 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
