Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 10-15-2011, 06:11 AM
richbear808's Avatar
richbear808 richbear808 is offline
Vehicle: 2010 Dodge Ram Quad Cab 4x2
richbear808 is on a distinguished road
Default Tire and Wheel Sizing Help
I have a 2010 Ram 1500 Quadcab 4.7 4x2 ST and I had a question about the Sizing of my rims and tires.
I am currently Deployed to Iraq so I cant look at my truck up close.
I want to get new Wheels and Tires but I dont know what size I will need. Are all ST rams the same size? All I know is that I need a 5 bolt.
Would these fit on there?
http://www.discounttiredirect.com/di...8.5&vid=017743
http://www.discounttiredirect.com/di...w=false&cs=265
Old 10-15-2011, 04:42 PM
Your bolt pattern is 5 X 5.5" or 5 X 139.7 mm so those wheels will fit as long as you get the right offset. The tires will work but they may be a bit too tall. I'd recommend at 65 aspect ratio tire.
Old 10-15-2011, 08:24 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
That tire is one of the factory sizes for the 2010. You'll have no problem with it. Good pricing on those rims too.
Those Grabbers are an okay tire - not superb, but ok. I had a set and they are pretty soft. If it's hot where you live they may not hold out too long.
Ask around about brands, lots of people here have first-hand knowledge of damn-near every tire going. It might be more valuable than a simple review.
Old 10-16-2011, 01:33 AM
Thanks Maddog! Lots of knowlage in here!
This might sound dumb but, what is off set?
Old 10-16-2011, 01:51 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Offset is the way a rim is set up relative to center placement:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
If the bolt circle is more towards the outside of the wheel (like a front wheel drive car) it has positive offset.
If the bolt circle is more towards the inside of the wheel, it has negative offset.
You have to make sure the rim offset is correct- otherwise you could have some horrendous rubbing/clearance problems......
Old 10-16-2011, 01:58 AM
Is there a website or link that I can use to see the Offset my truck will take? Internet is slow here in Iraq so a direct link or reply would be great! Thanks!
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 165 02-18-2016 08:35 PM
17" TRX wheel / tire help (w/pic) donn12 Dodge Ram Wheels And Tires 8 02-08-2011 07:54 AM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 11:40 PM
Verifying min wheel max tire - '06 Ram Sport Digipenguin Dodge Ram Wheels And Tires 0 09-28-2010 09:50 PM
Wheel / Tire Upgrade RAMitDOWN 2009 Dodge Ram Forum 5 07-28-2009 01:28 PM
