Old 10-15-2011, 09:25 AM
richbear808's Avatar
richbear808 richbear808 is offline
Vehicle: 2010 Dodge Ram Quad Cab 4x2
richbear808 is on a distinguished road
Exclamation Voiding Warrenty?
I just bought a 2010 Dodge Ram 1500 ST In February.
We all know the ST package doesnt come with anything so I wanted to buy a auto starter and a keyless entry remote for the truck. If I have someone install this, will it void my warrenty?
Old 10-15-2011, 09:37 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Big picture- no, your warranty will rmain in place. HOWEVER, if you have an warranty issue that can be directly tied to the remote starter/keyless entry install, the dealer has a legitimate reason to deny the claim.
The one way around this- if Mopar has the part available, and the dealer installs the part, the above situation is not a problem. May be a bit more expensive, but IMO is worthy of consideration.
All this is per the warranty booklet for 2011.
Old 10-15-2011, 11:35 AM
I push the skinny pedal
Rep:3277
I would just go to the dealer and have them install the factory keyless entry system w/ auto start. But, there are lots of options for auto starts, none of which I have ever heard causing warranty issues. I installed a Compustar 2-way on the gf's new caliber and the tech who did the last service on it never said a thing since they are VERY common up north.
Kurtis
Old 10-15-2011, 02:52 PM
The only reason they'd void the warranty is if the aftermarket system failed and did some damage to the truck.
You can get around that by installing a MOPAR accessory system as Kurtis ^^^^ suggested.
Old 10-15-2011, 08:47 PM
MRP's Avatar
MRP MRP is offline
Vehicle: 2010 RAM Sport 4x4
MRP is on a distinguished road
Agreed, I think the cost is about the same. I had a buddy with a problem with an aftermarket entry and he ended up going back to the dealer and install the factory system.
Mike
Toms River NJ
Leveling Kit, Power Chip (Diablo), Ridiculous Audio System, Custom Headlights w/ Leds
Old 10-16-2011, 01:48 AM
I already purchased a Vipar 2 way Auto start + keyless entry from (Dont kill me) best buy. And it comes with free installiation BUT, the "Professional" says that it will cost me a extra $115 because he needs to put a chip in order the auto start to work.
Old 10-16-2011, 05:04 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
If you have a Quad Cab with the factory Power Locks the truck already has all the keyless entry stuff. I bought a refurbed FOBIK and had a local tech program my truck and the FOBIK. Took about 10 minutes.
Chrysler and most techs will try to tell you it cant be done but it can.
-Add sales code GXM to vehicle options.
-Under Diagnostic procedures with Wi-tech do a restore vehicle reconfiguration.
-The Wi-tech will then reset.
-Go into the WCM under Misc functions hit the Reset WIN configuration.
-Clear all codes then program the new keys.
PS Worked like a charm with a $40 refurbed FOBIK on my 2010 Ram 1500 ST Crew Cab. Just make sure the key you get has the old vehicle info erased by the supplier or it wont program for yours.
Gene
Old 10-16-2011, 06:49 AM
Yes, My Quad cab has automatic locks. Thats not the problem tho, the problem is that the installer says that he needs to put a chip in the vehicle in order for the AUTO start to work.
Old 10-16-2011, 10:39 AM
Rep:24
Go to Best Buy- return the stuff you bought- get the factory stuff installed.
Less hassles, less worries, and no best buy to deal with....
Old 10-16-2011, 08:18 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
My dealer said if its mopar and they install it the warranty is good on that item.
If its mopar and I install it no warranty on that item
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
void, warrenty
Lift and your Warrenty ArmyRXP Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 09-28-2011 07:16 PM
Voiding the Warranty Sirchris Exhaust 12 08-22-2011 04:04 PM
Lifetime Warrenty Question dhopkins 2009 Dodge Ram Forum 9 06-30-2011 12:35 PM
voiding factory warranties Jmac86201 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 12-27-2010 05:39 PM
Mods Without Voiding MAllentaylor Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 04-01-2010 12:32 AM
