Looking for a good leveling kit - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-15-2011, 09:59 AM
macked macked is offline
Vehicle: 2011 Ram 1500
Rep:17
macked is on a distinguished road
Default Looking for a good leveling kit
Hey guys, I'm looking for a good leveling kit for the '11 Ram. I'm not sure if it's best to go with new shocks or a spacer kit, any opinions?
I don't want to break the bank here, but if the shocks are that much better a solution then I'm willing to spend what's necessary.
Old 10-15-2011, 10:12 AM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
I put a 2.5 inch Ready Lift on my 2011 Ram. I then installed 275/65/20 Dynapros. All looks good and no problems.
Old 10-15-2011, 10:23 AM
Rep:17
Just looked at the Ready Lift kit you mentioned. Have you experienced the "death wobble" thing they talk about on the website?
Also, is this something I should do on my own having 0 experience with suspension modifications, or just pay someone the labor to install for me?
Edit: Adding quote from Ready Lift website.
Due to a design issue with Dodge Ram front differential and suspension, some owners may experience a vibration in the front end when in 4x4 mode, or a violent shaking vibration of the front wheels when going over a bump at speed. These two symptoms are often called a "death wobble", but actually appear to be two different problems with the Ram truck.
The 4HI mode vibration is a vibration or shudder that occurs when accelerating in 4x4 high mode. This affects Dodge Ram 1500 non mega cabs; Dodge couldn't discover why their stock trucks would do this for some customers. The solution for Dodge was to state that there is no problem and that all of the new Rams will shudder or shake when in 4x4 high. This symptom appears isolated to 2006-2011 1500 non-Mega Cab model trucks and when in 4-hi mode.
It is ReadyLift Suspension's position that if you have installed a lift kit onto your Dodge Ram truck and experience either of the two symptoms mentioned, you have two options. 1). IMMEDIATELY HAVE THE LEVELING KIT REMOVED FROM THE VEHICLE! or 2). Install KORE High Angle CV Joints which will fix the factory issue.
Old 10-15-2011, 12:25 PM
Trim Level: laramie
I have the kit now for 6,000 miles and have no problems.
Old 10-15-2011, 01:46 PM
redlightrico's Avatar
redlightrico redlightrico is offline
Vehicle: 2015 Sport 4X2
Rep:15
redlightrico is on a distinguished road
I had the Pro-Comp 2.5" levelling kit installed and have had no issues whatsoever
The list is soon to be long....much to my wife's dismay
Old 10-15-2011, 02:06 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
A lot of people have used the Hell Bent leveling kit and have not had any problem with it. I have not had any problems with mine. I've had it over a year. If more information would have been available at the time I probably would have gone with the Bilstein adjustable shocks just because of their reputation.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 10-15-2011, 04:10 PM
Rep:17
Thanks for the help everyone, just ordered the Ready Lift 2.5" front end kit. I looked at the Hell Bent Steel kit, and even though it does look to be decent quality, the Ready Lift looks alot stronger.
Anyways, I should have it by next weekend, and being a suspension novice, I need to know is it a bad idea for me to attempt this myself?
I do not have any specialty tools for this kind of stuff either.
Old 10-16-2011, 04:31 AM
dieselholic's Avatar
dieselholic dieselholic is offline
Vehicle: 2011 Dodge Ram sport
dieselholic is on a distinguished road
Its not to hard to do. You will need a prybar, hammer, jack, jack stands, Wrenches, ratchet and sockets. If you have a compressor i would advice using that with an impact. The instructions with the ready lift are VERY detailed. But its all down to if you feel comfertable doing it. When you get the lift look at the instructions and see if you feel like you can handle it.
Old 10-16-2011, 07:50 AM
Rep:17
I need to update this thread, I cancelled the Ready Lift kit and ordered a couple Bilstein 5100 adjustable shocks. Seems like a better choice and the price was the same. Installation may be more difficult though...
Old 10-17-2011, 01:45 AM
Im on the same boat with you. The only thing else you need to do the job with thos is a spring compressor. Other than that is the same procedure.
leveling kit shocks
Front Spring leveling good/horror stories..?? SCHNELL Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 04-18-2011 08:21 PM
5" Lifted shocks on 2" Leveling Kit!? pieece Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 04-06-2011 10:53 PM
leveling kit plus suspension lift Jerkbait Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 03-15-2011 02:47 PM
You set my Truck up - leveling kit, wheels, tires fulton Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 20 03-06-2011 02:49 AM
New '11, leveling kit, subwoofer adjust, debadging questions?? wisconcb 2011 Dodge Ram Forum 9 02-18-2011 06:40 PM
