Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 10-15-2011, 01:27 PM
Hemi Rocket Hemi Rocket is offline
Vehicle: 2005 Dodge Ram 1500
Hemi Rocket is on a distinguished road
Question MIL Light Code PO406
I've got a code kicking PO406 which indicates a EGR problem... Rather than guess... I figured I'd ask first and save myself some time. 2005 Ram W/5.7L Hemi with about 40K on it. Any suggestions?
Old 10-15-2011, 03:20 PM
Here's the DTC info:
When Monitored: With the ignition on, battery voltage greater than 10 volts.
Set Condition: EGR position sensor signal is greater than 4.89V, one trip fault. (this means it's reading a high voltage signal at the sensor)
Causes:
EGR Position Sensor Signal Circuit Shorted to the 5-Volt supply circuit (bad sensor, not reading, causing high resistance)
EGR Position Sensor Signal Circuit Shorted to battery source.
EGR Position Sensor Signal Circuit open
Sensor Ground Circuit Open
EGR solenoid assembly
Basically, most of these types faults are caused by a bad EGR sensor. They will also arise if you have a stuck EGR valve.
Old 10-16-2011, 11:44 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Better to just replace with a new one. Its a easy procedure.
Old 10-17-2011, 09:27 PM
Thanks guys... a guy I was talking with this weekend said he had an 05 Ram with the same issue and it was the EGR valve... but rather than just guess thought there may be a diagnostic procedure. Can the EGR solenoid tested with an ohm meter... and can the connector pins be tested with a volt meter? If so, anyone have the test info.
Old 05-23-2013, 07:22 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
Were you able to resolve this? Just curious b/c it I am currently having issues with this code.
code, egr, engine, light, mil
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Airbag light w/ no code....Confuse SpecialEd Electrical 29 11-30-2013 12:51 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
check engine light code, please help interpret! MOPAR stallion 5.9L V8 Specific Topics 7 12-02-2010 12:15 AM
