Help!!! Bed Cover will not stay up by itself. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram Daytona
Old 10-15-2011, 01:03 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Default Help!!! Bed Cover will not stay up by itself.
One day it was fine the next it does not stay up by itself...it's like the shocks on each side stopped working. Any ideas? This is a nightmare as I use the bed a lot and it kind of defeats the purpose. Not sure what the things are called that allow it to go up and stay in place with a soft lift either???
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 10-15-2011, 01:14 PM
MADDOG MADDOG is offline
Rep:22
They are called struts and they do get weak in colder weather although they should stay up.
You can get replacements from the mfgr or take one down to the local auto parts store and see if they can match it.
A temporary fix is to raise the lid and clamp a small set of vise grips to one of the strut shafts, right below the barrel.
Old 10-15-2011, 01:19 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Thanks MADDOG. I've been struggling to figure out who makes this bedcover.I purchased the truck used and didn't think to confirm that when I purchased it. There is a stick under the cover somewhere but not sure if the mfgr name will be there.
Old 10-15-2011, 01:22 PM
Rep:22
You're welcome. More than likely you can just take one off and go to the local auto parts store to match one up.
Your struts may be riveted to the aluminum structure but that's OK. You can drill those out and use a bolt, nut and washer to fasten the new ones.
Old 10-15-2011, 01:39 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Gonna give that a shot. My assumption is that the current ones are shot and cannot be fixed so this cannot hurt. I'll report back...
Thanks again!!!!
Old 10-15-2011, 01:51 PM
Rep:22
You are welcome. Let us know how it goes!
Old 10-21-2011, 10:58 AM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
So I found some truck websites that sells gas props for fiberglass bed covers like mine. If I measure mine extended and collapsed and then match them on website should I be safe?
Old 10-21-2011, 02:04 PM
HoosierHemi's Avatar
HoosierHemi HoosierHemi is offline
Vehicle: 2011 Dodge Ram
Rep:115
HoosierHemi will become famous soon enoughHoosierHemi will become famous soon enough
sometimes with age, a lot of things won't stay "up" on their own
good luck with the fix though
2011 Black 1500 Sport QuadCab 4x4
Old 10-21-2011, 10:06 PM
Rep:22
Check the barrel diameter as well.
Old 10-24-2011, 06:26 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Hit my local auto parts store today and to my surprise, they had a set that worked perfect.Problem solved!
Bak Flip G2 Tonneau Cover MightyBlueRam Product Reviews 48 02-01-2014 03:57 PM
02-05 srt bumper cover over chrome 05atlanticblue Dodge Ram Knowledge Base 6 05-17-2010 03:32 PM
Cover vs Cover CustomShirts Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 12 04-26-2010 08:50 PM
Painting Engine Cover Incognito LD RAM - General Discussion 15 01-11-2010 11:14 AM
