Old 10-15-2011, 07:38 PM
hemipoweredram hemipoweredram is offline
Vehicle: 2005 Ram Hemi
Color: burgandy
hemipoweredram is on a distinguished road
Default No heat, soo cold, please help!
Tryed search but im in the booneys an on dial up this site loads sloww! I have a 05 ram hemi, My heater isnt working, doesnt blow hot or cold or at all, where should i start?
Old 10-15-2011, 09:00 PM
No fan? Check your HVAC system fuse.
Old 10-15-2011, 10:57 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
Start with the fuse as MADDOG suggested. Then the motor. More often than not, if the fuse is good and your not getting any air, it's the motor. Should be under the dash right above the passenger's feet. A fairly easy swap out if I remember correctly... To test, unplug it (it'll be a two wire, twisted harness, black and green wires) and test continuity between the two terminals ON the motor. If your multimeter reads OL, it's shot. Means there's no contact between the brushes and the stator. This is the most common test result. Just to be sure your motor is getting power, with the truck on, not running, and the fan motor switch on full, you should get voltage on the green wire... Hope this helps. Sucks to find this out this time of year...
Cold draft from under the seat? wjsamx 2010 Dodge Ram Forum 29 09-03-2012 12:28 PM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
Heat problem and door blend Dtimekw Heating & Cooling 7 12-08-2010 08:22 PM
Little Heat NCDEVILDOG Heating & Cooling 1 12-08-2010 08:11 AM
