Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 10-16-2011, 08:58 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
ND RAM is on a distinguished road
Default Change Oil Message!!!
I changed my first oil at 2300 miles. The truck has 3700 miles on it and I get the "change oil" message which leaves me to believe they never reset it when they changed it.
I can't believe this would come on in only 1400 miles but possibly at 3700 miles.
Without digging through my manual, how do I reset this thing?
Also, I took my truck on a 317 mile jaunt on a perfect no wind day traveling mostly on good 2 lane road and driving 65 mph. It was in very "hilly" country making it shift down occasionally.
It would slip in the "economy" mode occasionally also.
All I could manage was an actual 17.1 which was disappointing to say the least. The computer said 17.8 but I always go by actual fuel put in.
It's the Hemi with 3.92 gears.
Old 10-16-2011, 09:30 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
Turn the key to the start position but do not start the engine. Within 10 seconds depress the go pedal to the floor and back three times. The oil message light will be gone now.
sales@revelperformance.com
Old 10-17-2011, 03:04 AM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
had my oil changed at 1000 miles and the message just came on at 3500 miles. so 2500 miles driven, easy miles too- just highway to and from work. there's been countless threads like this which leads me to believe Chrysler's oil monitor system is garbage...much like their fuel economy calculation.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 10-17-2011, 10:32 AM
johncran johncran is offline
Vehicle: 2011 Dodge Ram
johncran is on a distinguished road
Is the monitor system adjustable to different interval settings? My Toyota let me select my own intervals, I think there was 5 or 6 to choose from.
Old 10-17-2011, 01:22 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
mine came on at about 3700 miles over the w/e. i had changed it myself at about 100 & 2000 miles without resetting. now i know.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 10-17-2011, 01:28 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
No way to change the interval that I know of. It's duty cycled so the interval is dependent on how you drive. I think it comes on way to soon considering the recommended oil change interval according to the manual is 10,000 kilometers or 6,000 miles. Since I change my own oil I just reset it when it comes on and change the oil according to my own schedule, which is every 6000 kilometers.
Old 10-17-2011, 01:42 PM
lowrpmtork's Avatar
lowrpmtork lowrpmtork is offline
Trim Level: Sport Crew Cab 4x4
lowrpmtork is on a distinguished road
With your low 3.92's at 65MPH, that GPM is about right. I have 3.55's and find that the MDS doesn't activate very often at or above 65. To help with the price at the pump and if I'm not in a hurry, I rarely set my cruise above 65 even if I'm in a 70MPH zone. I'm averaging around 17 but if it's just back and forth to work (hilly 45-50MPH 8 mile trek) I get 19-21 MPG depending on wind.
As for the oil, there are several modes of thought on this, but the manual states a change every 8K and makes no mention to the first one being any sooner. So, "my" mode of thought on this is the first change on any newer engine isn't critical like they used to be. This is because everything now are roller motors rather that flat-tappet which need high zinc oil and a "break-in" period for the lifters and cam to get a proper wear pattern and rings to seat. Then, after the first 500-1000 miles, if you did not have the luxury of a dyno to do the work, you must change the oil the get the assembly lube and any break-in materials out. The new motors and building methods have much tighter tolerances and are good to go from the first start (essentially). Now, if you want to change your oil on an earlier schedule, that certainly will not hurt, you will just go through a few more filters and oil more than what I would. In the end, it's all up to you.
Cheers
2011 Ram 1500 Sport Crew Cab 4x4
Yeah, it's got a Hemi...
Old 10-20-2011, 10:01 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I was going to say the book states 8000 miles. I just had my oil changed at about 3200 miles. My change oil light came on at 3500 miles? I do not think Chryslers oil change light is anything special.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
2011 Ram Oil Life Per Oil Change uncletony76 Oil Change 32 10-20-2015 08:03 PM
Deleting Message - for oil change E220 Oil Change 6 11-23-2012 01:39 AM
Resetting the oil change message flash105 Oil Change 4 12-13-2011 07:39 PM
Oil Change Message killerbee 5.7L (345 cu in) HEMI V8 Specific Topics 5 07-23-2011 01:52 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 02:00 AM
