ZDOG
Old 10-17-2011, 12:28 PM
chuckie chuckie is offline
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
chuckie will become famous soon enoughchuckie will become famous soon enough
Default 2011 r/t custom intake tube
Since no one makes an intake tube only for 2009 and newer I made my own:
Parts needed:
airaid u-build-it kit 100-350 3 1/2"
http://www.airaid.com/ProductDetail....ductID=100-350
It is a big loop of plastic pipe with various angles, I used a 45 degree
at the airbox and a 90 degree at the throttle body. Cuts real clean with
power mitre saw.
Silicine hose couplers from HPS
http://www.hps-siliconehoses.com/
I used coupler HTSC-350 at the throttle body and in the center junction.
At the airbox I used flex/hump coupler HTSHC-350.
6 stainless T-clamps needed
The rubber grommet for the air temp sensor: OMAR-2761
http://search.cableorganizer.com/ind...0&Ntk=products
I used a #4 unibit to drill the hole. Run the bit all the way through to make
a clean 7/8" hole. Regular drill bits will not make a good hole
Total cost around $200
Very happy with results, running k&N drop-in and fastman throttle body
Old 10-17-2011, 04:02 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
How's the Butt dyno?
Old 10-17-2011, 05:13 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
For another 100 you could of got a cia were you just trying to get rid of the ribs on the tube
Old 10-17-2011, 11:56 PM
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
I tried an AFE stage 2 - hated the noise it made no obvious power gain and sold it.
The K&N drop-in / smooth intake tube / fastman throttle body works for me fine.
No noise and all 3 mods together have definitely improved throttle response.
In fact intake temps are about 10 degrees cooler with this setup compared to the AFE
I tried. I have an aeroforce interceptor gauge that measures that
Old 10-18-2011, 01:24 PM
Moparzrule's Avatar
Moparzrule Moparzrule is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Hunter Green
Moparzrule is on a distinguished road
I'm hoping Vararam come out with this one soon.
Old 10-18-2011, 06:12 PM
sincebeen's Avatar
sincebeen sincebeen is offline
Vehicle: 2012 Ram 1500 CrewCab
Rep:72
sincebeen will become famous soon enough
Actually this IS a CAI. The only difference between this and the Volant is the presumed amount of airflow through the filter... which is debatable since he's running a K&N drop-in.
Nice work Chuckie!
Old 10-18-2011, 07:39 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
Yep looks good but come nov 1st i can get brand new k&n cai for 115 so ill just wait
Old 10-18-2011, 08:56 PM
daddymountainman daddymountainman is offline
Vehicle: 2011 dodge ram RT single cab
Trim Level: rt
daddymountainman is on a distinguished road
Default k/n
where can you get a k/n for 115 will you let me know?
Old 10-18-2011, 09:58 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
Where'd you fine that pic? Do you have any inside info on it?
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 10-19-2011, 12:19 AM
Moparzrule's Avatar
Trim Level: R/T
Color: Hunter Green
Let me just say it's on a competitors Ram forum site. There's alot of discussion about when it's being released for the gen4 Ram. It's available for the Gen3 Ram now. Very cool can't wait to get one on my R/T.
oem intake tube swap autobred Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 36 05-01-2012 11:15 PM
Airaid intake tube for '09-'11 ? chuckie Dodge Ram R/T 1 08-16-2011 04:38 PM
XTRA POWER MOD moved IAC sensor from Manifold to Intake tube RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-09-2011 09:05 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
