ZDOG
Old 10-17-2011, 07:30 PM
old amateur's Avatar
old amateur old amateur is offline
Vehicle: 2011 Ram 1500 Crew
Color: red
old amateur is on a distinguished road
Default 1500 weakness fix
Hope I'm posting in the correct spot.
Been reading thread after thread after thread etc..... and thought I'd start one to answer a few questions of my own.
If you were going to lift your truck, how would you do it? What issues need to be overcome? (Readers Digest version will do just fine .)
For example: I would like to lift my truck to accomodate either 35's or preferably 37's. I have a 5 position drive option (2H, 4Auto, 4H, 4L Neutral). I search for 6" lifts yet most (if not all) have a disclaimer the lift is not for AWD trucks. Is 4Auto the same as AWD? If so, why won't the lift work?
Stock tires are 32" tall. Will moving up to either a 35" or 37" cause premature wear on bearings, CV shafts etc? Why and how do I compensate?
Will an aftermarket lift cure the 'death wobble' I keep reading about?
Is a gear swap necessary and (without sounding like a moron), what gears are we speaking of (differential, transmission, both)? How do I know what gears are in the truck (I don't have the build sheet)?
By the way, I am mechanically inclined, just not experienced in this particular field and I am one of those people who just has to know
Cheers,
Old 10-20-2011, 04:07 PM
shujat shujat is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Sport 4X4
Color: Mineral Gray
Rep:19
shujat is on a distinguished road
bump for the good question, I hope someone can help!
Old 10-20-2011, 04:34 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
If you want to lift more then 2.5" you want a lift kit that has new crossmember and lifted knucles. By going this route it keeps the CV axles at nearly the same angle they are at so you should not experience death wobble.
Another option with this type of kit is you can use Bilstien ride height adjustable shocks to make the truck sit closer to level.
4auto is different from AWD drive. If you have the 4auto T case then you will be fine lifting your truck
With 35" tires you will be fine. 37's are ok but are at the point that its a little to much tire to turn with stock gears usually.
You can tell what axle ratio by looking at the tag in your glovebox or I believe there is one on your axle as well
A good gear ration for 35's is 4:10, 37s would be good with 4:56
Although a gear swap isnt completly neccesary it is recomended
Old 10-20-2011, 09:22 PM
Color: red
Thanks. I'll check out those locations for gear info.
I some questions regarding box liners and cat back systems though I'm sure there's a better spot to post those.
cheers,
Old 10-20-2011, 09:35 PM
Color: Mineral Gray
Rep:177
What size lift are you looking for and what do you want to do with your truck after it is lifted?
Old 10-20-2011, 10:03 PM
Color: red
Lift size would be at least 6" with a possible body lift to accomodate 37's. No particular reason for 37's other than I like the look.
Use? Pretty much a mall crawler however I tend to be a little unpredictable at times and may decide to take the thing off road (known to do that)!
Old 10-21-2011, 01:09 AM
Color: Mineral Gray
Rep:177
The rough country lift would be a good option for you then if your not looking to break the bank
Old 10-21-2011, 10:30 AM
dayone's Avatar
dayone dayone is offline
Trim Level: ST Quad Cab 4X4
Rep:28
dayone is on a distinguished road
just so you know, the 2011 ram r/t comes stock with 4.10s so the 4.56s maybe a better option. the stock gears now are probably 3.55 unless you have the the 3.92 option which would be on the window sticker. when you increase the tire size that much you need to correct the gearing in order retain applied power and fuel economy. i have heard of gas mileage going up with larger tires when the correct gears were added. there are calculaters available online to check this.
Old 10-21-2011, 11:48 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Rough Country 6" lift and 37s will do you well! Also whether you have 3.92 or 3.55 you'll be fine. I've put 10K miles with 37s and 3.55 with no issues. As far as swapping out gears, that's a no go on the 11s. You'll have to wait a while for an gears, lockers or an lsd to be availible.
[CENTER][SIGPIC][/SIGPIC]
2500 and 1500 Differences?? hotchiliram 2012 Dodge Ram Forum 13 08-19-2011 03:11 AM
Dudes please help me out!!! 2010 cummins vs 1500??? Elite Cummins Diesel Specific Topics 31 07-25-2011 04:24 PM
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-02-2011 11:38 PM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
