Old 10-17-2011, 08:35 PM
mark1963 mark1963 is offline
Vehicle: 2003 Dodge Ram 1500
mark1963 is on a distinguished road
Default oil smoke from exhaust when heats up when ACCELERATED ONLY,??
this smoke started friday after i used a can of mopar combustion chamber cleaner from the dealer, it only smokes when i stop & go at a light or idles for a few then given gas, does not smoke at all driving or idling with out being accelerated, took it to the shop today, it has good compression, plugs were clean, removed pass side valve cover, inside was very clean, no sludge at all, they told me it seems like valve guide seals, but it does not smoke at start up in the morning like you would think w/bad seals, and the truck needs heating up first, did something happen when i used that mopar cleaner,?? ( please help ),
Old 10-17-2011, 09:14 PM
02Ram4x4 02Ram4x4 is offline
Vehicle: 2002 Ram
02Ram4x4 is on a distinguished road
it does sound like valve guide seals, or worn guides, when you used the cleaner you might have dislodge somthing that was sealing that leak, try some motor honey or try high milage castrol. also is the smoke white or blue?
Old 10-17-2011, 09:28 PM
it looks more bluish, but again it does not smoke in the morning, only after it heats up & after you stop at a red light and accelerate does it puff a little smoke, also accelerating after idling,??
Old 10-18-2011, 04:54 PM
440Magnum 440Magnum is offline
Vehicle: 2008 Ram 1500
Trim Level: Lone Star
Rep:26
440Magnum is on a distinguished road
How did you use the can of combustion chamber cleaner? Add to fuel? Dump down intake? If you added it to the fuel, burn the whole tank of fuel and then see if it still smokes with a fresh tank and no cleaner.
Old 10-18-2011, 06:55 PM
Default cleaner & compression,!!
it was the can that you spray into the throttle body, NOW ABOUT THE COMPRESSION I WAS TOLD WAS GOOD, i showed the receipt to the dodge dealer today & seen what the COMPRESSION WAS BETWEEN 89psi TO 93psi they told me it was way off, it should be more like 180 to 190psi, somone did not know what they were doing, they also told me that if my COMPRESSION WAS REALLY THAT LOW IN ALL EIGHT CYL THAT I WOULD NOT HAVE ENOUGH POWER TOO DRIVE MY TRUCK ( IS THIS TRUE )
burning oil lot of white smoke jula123music 4.7L PowerTech V8 Specific Topics 14 08-11-2011 12:59 PM
Burning oil...whiteish smoke sometimes lilbob04 4.7L PowerTech V8 Specific Topics 6 06-30-2011 11:52 AM
Problem: Coolant smell from engine but no smoke or water in oil (see pics) elektromaniak Heating & Cooling 7 06-04-2011 07:50 AM
smoke from the exhaust kraftfahrer 5.7L (345 cu in) HEMI V8 Specific Topics 8 03-09-2011 03:36 PM
