Old 10-17-2011, 09:35 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Default 45RFE, 545RFE and 645RFE Longevity
45RFE, 545RFE and 645RFE longevity.Any guys with over 150,000 miles on the trans? If so what maintenance intervals did you use?
Gene
Old 10-17-2011, 09:40 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Interested too. Also post your driving habits too if you can please. Thanks.
Old 10-17-2011, 10:46 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
I have 160,000 miles on my 2002 45RFE. I bought the truck used, and it had 110,000 miles on it then so I dont know of previous fluid and filter changes. I did change the filters and fluid when I first bought it and they appeared clean, but not sure of previous intervals. I plan on changing again in the near future but am in no way going to buy the 30,000 services the manual calls for. I am fairly certain that this is the original transmission as well.
My driving style is mostly spirited, but do get on it at times, and also "drive Mrs. Daisy" at other times.
Sure it'll suck, but it'll make you a man
Old 10-19-2011, 08:18 PM
Severe Duty on my 2010 is actually 5/60,000. I know the Synthetic ATF+4 is worlds better than the ATF+3 Synthetic-Blend much less the older stuff and I use to 30,000 mile changes on the old conventional fluid.
Right now my plan is to just change it every 3 years (likely 24,000-30,000 miles in my case) but since I dont do flushes I only get about half the fluid each time.
Gene
