Old 10-16-2011, 05:49 PM
facehugger facehugger is offline
Vehicle: 2010 Ram Laramie cc rambox
Color: brillant black
Rep:29
facehugger is on a distinguished road
Default intake manifold
Does anyone knows where to get a ported intake manifold for a 2010 HEMI ?
I can't find anything yet
Thanks for helps
2010 crew cab Laramie RamBox
Recon smoked headlights, taillights & 3rd brake light - tribal Grille insert - grille blacked out - Gibson catback split exhaust system - oval premium side steps - spray in bedliner - Diablosport Trinity 93 oct tune - air deflector chrome style - Volant CAI - carbon dash kit - interior LED replacements - Arrington 90mm tb - Bakflip
Old 10-16-2011, 08:46 PM
moparornocar72's Avatar
Rep:630
The only aftermarket Intake manifold I have seen so far is the xv motorsports one. Haven't heard of anyone using it yet, but I believe some are running the 6.1 intake manifold if I'm not mistakin, this intake would only be good if u had forced induction.
Here is the link to the xvmotorsports intake though.
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=272&cid=167&cdesc=LX%2FRAM%2FJeep
14.268 @ 95 MPH Full Trim
Old 10-16-2011, 09:37 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
6.1 manifold will line up with with your ports but still $$.
Old 10-16-2011, 09:53 PM
I push the skinny pedal
Rep:3308
Thanks for helps
Here are your options:
6.1L intake manifold - you need to machine the timing cover and get the bracket to spread the alternator and A/C. The ports will match up no problem. Inertia motorsports sells the timing cover and bracket.
XV manifold - unless you're planning forced induction then this isn't the manifold for you as it will kill the bottom end in a N/A situation.
and that's about it for your options. You can't port the OEM manifold as it's plastic.
Kurtis
Old 10-16-2011, 11:45 PM
2010 ram 2010 ram is offline
Vehicle: 2015 Ram CrewCab 1500 4x4 8spd
Color: True Blue
2010 ram is on a distinguished road
that manifold at xv make is pretty sweet
Old 10-17-2011, 01:12 AM
Rep:630
yeah but at $619 forget it, also the cost for forced induction for it to suffice. 6.1 would be cheaper.
3.9/5.2/5.9 Intake Removal & Installation RamTech Dodge Ram Knowledge Base 6 08-28-2013 06:03 PM
Intake Manifold Performance/repair 97ram2500 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 10-04-2011 04:31 PM
XTRA POWER MOD moved IAC sensor from Manifold to Intake tube RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-09-2011 10:05 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 03:16 AM
Intake Manifold Ram50Man Dodge Ram General Discussion 2 01-19-2011 09:09 AM
